Sponsored by: Auxito
Intake runner control
Old Dec 8, 2018 | 12:32 PM
bearfoot_25's Avatar
bearfoot_25
will my 2001 F150 super crew with 4,6 V8 have the intake runner control on it? It has the aluminum intake on it if that helps.
Old Dec 8, 2018 | 04:05 PM
Sam I Am's Avatar
Sam I Am
no
Old Dec 9, 2018 | 08:41 PM
Bluegrass 7's Avatar
Bluegrass 7
Take a look down under the front of the intake behind the Alternator looking for a wire harness going to a connector.
If you see this, yes the intake has a different version of intake runner control.
If not, you should se a round area where the driver motor would be that would drive a long flap valve inside the lower section bolted to the bottom of the upper intake.
It is seldom ever talked about or ever causes a code to set.
My 02 4.6 has this control.
Normally it is closed to force the intake tract into a longer path.
This enhances low end torque up to about 3000 rpm +/- then closes to shorten the path for higher RPM power.
Most of us never get above 3000 rpm in normal relaxed street driving so the runner may never get involved.
My 292000 mile motor pulls hard off idle and really gets with the show above 3200 rpm all the way to over 5000.
I would assume it is working as designed.
aldo_45030
Jul 29, 2015 07:01 AM
WV Hound Dog
1997 - 2003 F150
Feb 16, 2008 10:15 PM
lifted77f250
Dec 29, 2007 02:10 AM
faceman1
Jun 14, 2007 10:03 AM
pkulaga
20
May 10, 2006 03:36 PM
