What would i have to do to use a mustang HO intake into a 91 302? Any electrical that needs changing? Can i use the truck sensors or do i need the mustang sensors? Any help would be appreciated.
The intake will bolt right on and the truck sensors can be used. The biggest problems will be with the intake plumbing(single blade TB on the HO versus dual blade on the truck), the throttle control cable and possible tranny control cable depending upon what transmission you have. A HO intake complete with EGR valve, TB and control cable plate would be the best way to go. Maybe compare the 2 systems yourself before you take the plunge so you know what you're up against.
I was under the impression that the Truck intake flows as well if not better than a Mustang's stock intake.
Yes, but a high flowing intake on a wheezer motor like the truck 5.0 makes for very weak low rpm TQ production. The HO intake will make 300lb ft TQ from 2000rpm, the truck intake is much less at that rpm.
I may be wrong, but I see no worth in swapping a standard HO intake off a Mustang on to a truck. With long v/s short runners, you're just moving the power band around a small amount. These trucks are made for pulling and I don't know about you all but I really never needed to turn rpm's to red line in my F250.
Like I said before, the truck intake has more port volume. So if I did do a HO type setup, it would be a GT40 style like the Gen1 Lightning had, or something like the Trick-Flow, Edelbrock, etc. I'd skip right over that 5.0HO intake with its smaller port volume.
The rule of thumb about longer intake runners is valid, but TQ production it's also tied to runner volume, smaller runners generate more intake velocity at lower rpms and more torque as a result. It's been my observation that the 5.0 truck intake is just simply too big to produce usefull low rpm power. This is backed up by recent dyno results from another user here, the 5.0 truck intake actually made more HP than the HO intake. The fact that the HO motor makes more TQ than the truck motor is more fuel on the fire. The 5.8 intake uses smaller runners than the truck 5.0 and produces substantially more low rpm TQ, some of that resulting from the increased displacement, but the rest is from the intake. IMO, the HO intake is a step in the right direction for a stock or mildly upgraded truck 5.0, adding a 1" spacer between the upper/lower lengthens the runners and should boost low rpms even more. Lots of others have already built 5.0's with the GT40 or other aftermarket big volume intakes, and every time they report it absolutely killed low rpm power.
