Excursion "Geography" help needed
Old Dec 5, 2018 | 10:41 AM
cpchampion's Avatar
cpchampion
My '04 Excursion (4x4, V10) windshield washer pump isn't firing even though the wipers are functioning. I read through the excellent example of troubleshooting in a similar thread about rock2610d's 2001 Ex, and symptoms are very similar.
My problem: locating the washer pump relays under the hood to know which ones to test. All I have on hand is The Book of Haynes, which has a wiring diagram for the wiper/washer system but doesn't provide hints on which underhood relays are which. With it being 11* F out in the driveway right now, the thought of crawling around to squint at the wire colors going into the bottom is... um, unappealing.
So, can any of you FTE Excursion Experts provide some pointers on where I'll find the relays, and hopefully spare me from frostbite during troubleshooting?
Thanks in advance.
Old Dec 5, 2018 | 11:33 AM
ArmyLifer's Avatar
ArmyLifer
On my 2000 Ex, the relays for the washer pumps are #206 and 209 in the under hood fuse box. Don’t know which is which. Also don’t know if my 2000 would be the same as your 2004.
Old Dec 5, 2018 | 12:05 PM
cpchampion's Avatar
cpchampion
Unfortunately not. The 2004 doesn't have a fuse box under the hood there at all. There is a bracket with about 5 or 6 relays on or near it, but all fuses got relocated to under the dash. At least knowing that the old location was about there (I'm assuming that's just behind the FL wheel well, right?) is helpful in that I can hope Ford didn't decide to move the relay all the way across the engine bay... but who knows.
Old Dec 5, 2018 | 12:09 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I don’t have the 04 factory manual or I would look it up but if it is user serviceable it will be in your owners manual
Old Dec 5, 2018 | 12:47 PM
unleashd's Avatar
unleashd
@cpchampion Welcome to the FTE!
@ArmyLifer and @pirate4x4_camo Are the electricals same for the V10 and PSD?
Old Dec 5, 2018 | 02:11 PM
cpchampion's Avatar
cpchampion
Thanks, unleashd. I've actually been a member of the forum for 3.5 years, but it's such a good resource that this is the very first time I haven't found a definitive answer for what I needed to know.
Old Dec 5, 2018 | 04:51 PM
pirate4x4_camo
in the same model year the chassis stuff is mostly the same but obviously the powertrain systems are diffrent,
the last 7.3 was 2003 and the OPs vehicle is an 2004 so there are going to be major differences like no GEM, gage cluster ect.
Old Dec 6, 2018 | 12:29 PM
DetroitEx's Avatar
DetroitEx
if i recall, on 2004 the washer relay is integrated into the front wiper motor...
Old Dec 7, 2018 | 02:11 PM
Dave's here's Avatar
Dave's here
Make sure to check all vacuum lines for animals chewing thru them, that is how I figured out why my rear windshield wiper squirter wasn't working.
Old Dec 8, 2018 | 02:27 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by cpchampion
All I have on hand is....
Go to the tech folder (even though the coding is crewed up...working on that with IB) and download the owners manual from the links in the first post.
Stewart
Old Dec 11, 2018 | 11:31 AM
cpchampion's Avatar
cpchampion
I do have a PDF of the owner's manual, and it lists no location for the washer pump relay. It only lists out the relays that are in the under-dash fuse panel. So it'll be handy if my rear window defroster stops working, but no use for this.
Thanks for the help. Unless someone has a secret Ford-tech manual that has insider info, I guess I'll grab some handwarmers and start checking the wire colors going into the relays on the left side of the engine bay to see if it's there or if it's integrated into the motor as DetroitEx thinks may be the case.
Old Dec 11, 2018 | 12:16 PM
Stewart_H's Avatar
Stewart_H
I just realized I missed the quoted post below, posted previously in the thread:
Stewart
Old Dec 11, 2018 | 01:00 PM
DetroitEx's Avatar
DetroitEx
item 7 in the wiper motor/schematic is the washer relay. for me, i have an 01, and the relay is still in the underhood box...
NDL
1983 - 2012 Ranger & B-Series
Apr 20, 2016 07:59 PM
gasturbo
Sep 18, 2015 02:26 PM
outlaw17
Electrical Systems/Wiring
Dec 29, 2011 09:20 AM
Fire Joe
Oct 15, 2010 06:07 PM
ricktoro
Apr 28, 2006 08:47 AM
