Sun visor falling downward. Easy fix??
Old Nov 27, 2018 | 12:50 PM
gittinwidit's Avatar
gittinwidit
Got one about to irritate me to death. Falls downward constantly sunny or not. Anybody have a fix? I tried searching and didn't come up with anything but I feel for certain I'm not the first to have this issue. Hard to guess the words to search???
I've considered stabbing toothpicks in the hole or spraying something tacky in there. Just wondering if there was a consensus to a good easy fix.
Thanks!
Old Nov 27, 2018 | 01:26 PM
beartracks's Avatar
beartracks
Same problem. All my parts are new and properly installed and still they fall down. I've tried wrapping the pins with different things to no avail.
Old Nov 27, 2018 | 01:56 PM
four-sixty-power's Avatar
four-sixty-power
Remove 3 screws holding visor to inside of cab.
Remove visor from metal rod.
Bend metal rod to create resistance against visor when positioned up or down, but still straight enough to not be noticeable.
Install visor on metal rod.
Install visor to inside of cab with 3 screws.
Old Nov 27, 2018 | 02:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Lower pic: Inside the visor is a C shaped metal tube. When the visor rod (04144 in pic) and visor end rod (04115) are inserted, the tube expands.
Over time the expanded tube will no longer retain the rod and rod end properly, so the visor sags.
If your truck has the plastic visor rod with the rubber tip, it wears down, causing the visor to do the "flip-flop."
Old Nov 27, 2018 | 02:51 PM
EQCMCAT's Avatar
EQCMCAT
My passenger visor falls down as well. I was also considering applying some adhesive (tacky) spray inside the rod area, just as Beartracks suggested and or some how stuff a piece of cloth inside the rod area. I've already replaced the center rubber ends (caps) and that didn't help.
Old Nov 27, 2018 | 03:58 PM
76F250SuperCab's Avatar
76F250SuperCab
I've had this problem on a couple of Ford visors. As mentioned above, I removed the visor from the truck, then removed the visor from the Rod. I then used a vise or vise grip and even a piece of wood and a light hammering to close/ tighten the C clips inside of the visor. Be careful here not to scratch up the visor, but it needs some force to close the inner metal clip. The simply reinstall the visor rod. It should be nice and snug again.
Old Nov 28, 2018 | 10:09 AM
HoustonDave's Avatar
HoustonDave
Clear RTV or similar - put a small amount on a #1 Phillips screwdriver shaft and lightly coat the inside of the hole where the visor pin goes. Let dry, insert the pin. Lasts years and does not show, no need to bend the pin. If the first coat is too thin, try again.
Old Nov 28, 2018 | 05:20 PM
5851a's Avatar
5851a
This is what I do too.
v6lightning
Jul 11, 2013 11:34 AM
Indybeer
Sep 30, 2010 12:18 PM
renoduckman
1983 - 2012 Ranger & B-Series
Jun 29, 2008 11:25 AM
imlowr2
Aug 4, 2007 05:00 PM
ford-nut
Nov 26, 2006 11:00 PM
