In dash navigation mod
Old Nov 23, 2018 | 08:20 AM
LegalDiesel's Avatar
LegalDiesel
I'm new here, and I must not be able to figure out the search que, because I found nothing when I tried, and I'm certain this has been a thread before. So please excuse my ineptness in finding one. I am looking to replace the factory satellite radio with an in dash double din unit with navigation. I have a couple of quotes from shops on the mod, but when I went to Crutchfield to check on units, the web site would not recommend any. It said replacing my factory radio was not recommended, as the weather apps are part of the factory unit? Has anyone else had this issue? Can the factory be replaced? I have a 2016 F250 XLT that I am slowly turning into a Platinum in terms of features. I already have replaced the seats with leather, put retractable running boards on it. Now want to upgrade the factory radio for an in dash system. Thanks for the advice and help.
Old Nov 23, 2018 | 08:40 AM
bcg's Avatar
bcg
Do you have an 8" Sync in your truck right now? If so, I can help you upgrade that unit to one with Nav. What needs to be done will differ depending on if it's a Sync 2 or Sync 3, if you've got a Sync 2, I'd definitely recommend going to the Sync 3, it's navigation is a lot better and it supports Android Auto and Apple Car Play.
Old Nov 23, 2018 | 04:48 PM
LegalDiesel
I have no idea what Sync it is, as i have never used it nor the bluetooth. I have a Sync port to the right and below the radio, with a USB receiver on top and a plug receiver on bottom. Does that help? It is a standard radio, with satellite, and a CD player.
Old Nov 23, 2018 | 05:43 PM
Just Strokin's Avatar
Just Strokin
any photos of what you are describing?
you can read this link and see if it pertains to your radio
Enable navigation on cars with Sync … Windows Mobile Development and Hacking
Old Nov 24, 2018 | 06:28 AM
Superdave71's Avatar
Superdave71
Are your leather seats heated and cooled? On the factory heated/cooled leather aftermarket nav becomes difficult because aftermarket doesn’t support controls for their operation. But sync 3 will....
Old Nov 24, 2018 | 08:25 PM
MikeRizz's Avatar
MikeRizz
So does this enable Navigation for a truck not equipped with it? I have a 2015 F-350 Lariat.
Old Nov 24, 2018 | 08:31 PM
ford390gashog's Avatar
ford390gashog
That process no longer works and hasn't in a while. Ford closed the loophole on as built data.
Old Nov 24, 2018 | 10:29 PM
bcg's Avatar
bcg
It works on the Sync 2, not the Sync 3.
Old Nov 25, 2018 | 10:21 AM
MikeRizz's Avatar
MikeRizz
My truck has the 8" touch screen, is that Sync 3?
Old Nov 25, 2018 | 11:39 AM
bcg's Avatar
bcg
Both have an 8" screen. Can you post a picture of your screen turned on? The Sync 2 has the home button on the bottom middle, the Sync 3 has it in the top left.
This is the 3
Old Nov 25, 2018 | 12:29 PM
ford390gashog
Your truck has Sync 2. Only the 2017+ trucks got Sync 3.
Old Nov 26, 2018 | 07:17 PM
MikeRizz's Avatar
MikeRizz
Thank you. So the above mentioned Forscan and SD card mod should work?
Old Nov 26, 2018 | 07:18 PM
MikeRizz's Avatar
MikeRizz
This is the 3
Thank you. My home is in the middle/bottom so Sync 2. So that mod should still work?
Old Dec 2, 2018 | 05:07 PM
MikeRizz's Avatar
MikeRizz
So I did this mod today and it worked! My truck now has navigation for the cost of a $35 SD card and about an hour of my time ( note I already had Forscan and the OBDII adapter ).
dlynnn22
Aug 28, 2011 12:34 AM
japaleno
Mar 20, 2011 10:46 AM
78f250lj
Nov 9, 2008 08:05 PM
newtuner
May 23, 2006 04:13 PM
jcarey123
1997 - 2003 F150
Nov 13, 2003 08:14 PM
