mirror repair
Old Nov 22, 2018 | 07:52 PM
blue351's Avatar
blue351
mirror repair
Is there a thread or topic on how to repair sport mirrors. when I removed them the bolts were rusted and the rivets turned out . is there a fix for this issue ?
thanks
Old Nov 22, 2018 | 09:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks
FoMoCo never called it a Sport mirror. This is the ridiculous name that LMC gives to the 'standard equipment' left side Passenger Car type mirror, shown as TYPE 5 in pic.
The 1967/72 mirror is the exact same as the Passenger Car mirror (C7AZ-17696-G), the 1973/79 mirror has a larger mirror head (D3TZ-17696-L).
There are no parts available for these mirrors, when the mirror head begins to sag, or the glass breaks, it's time for a replacement.
Old Nov 23, 2018 | 10:22 AM
blue351's Avatar
blue351
its a mirror similar to type 5 in the picture. the base that attached to the door is what is giving me trouble . just looking for ideas on a fix. I have new mirrors so they are good to go. just need to figure out how to install securely to the door.
79 f150
thanks
Old Nov 23, 2018 | 04:11 PM
EQCMCAT's Avatar
EQCMCAT
You might consider foregoing replacing the rivet nuts and use stainless steel screws with body washer on the inside of the door and stainless steel nylon lock nuts.
Old Nov 23, 2018 | 06:40 PM
72rtchallenger's Avatar
72rtchallenger
I like the rivet nut inserts pretty good, use them on many things
Old Nov 23, 2018 | 07:14 PM
blue351's Avatar
blue351
whats a rivet nut ? got a picture ?
thanks
Old Nov 23, 2018 | 07:17 PM
blue351's Avatar
blue351
I have the same issue on my tailgate . cant figure out how to fix that either. the bracket that holds the latch on the tailgate has a similar arrangement. apparently the threaded part inside the tailgate fell out and now I have nothing to screw the bolt to.
Old Nov 23, 2018 | 07:40 PM
72rtchallenger
thanks
Just google nutsert ,, it takes a special tool to install but its not that expensive,,search ebay,,there the same thing that held your mirror on originally on most
NS70250
13
Mar 22, 2020 08:49 PM
78ferd
Feb 21, 2014 06:41 PM
avenge
Feb 19, 2013 04:50 AM
66F100Again
May 22, 2009 02:59 PM
mr4speedford
Sep 15, 2002 05:17 PM
