Radiator Support Interchange
Old Nov 21, 2018 | 02:01 PM
PurelyFord's Avatar
PurelyFord
Will a radiator support from a 1979 F150 fit a 1976 F100? I know the headlight buckets are different since the 79 has rectangular headlights? Just not sure if everything else bolts up the same. I found one in excellent shape and for cheap to replace my rusted one.
Old Nov 21, 2018 | 02:06 PM
meangreen92's Avatar
meangreen92
It should. I think some fleet '79s might've still had the round headlights? Maybe it's one of those.
Old Nov 21, 2018 | 02:09 PM
PurelyFord's Avatar
PurelyFord
Ok. Nope, it has rectangular headlights and grill to match.
Old Nov 21, 2018 | 10:35 PM
four-sixty-power's Avatar
four-sixty-power
To swap your 76 headlight buckets onto the 79 rad support you should only have to drill 2 new holes for each headlight bucket to lower them to the 76 height as there are existing holes for the others. So there are already 2 holes existing, and you have to drill 2 new holes, for each headlight bucket. So drill 4 new holes total. Just look and compare the 2 rad supports and you can figure out where the new holes get drilled, these might even be the slotted holes so you don't have to be that accurate. IF I REMEMBER CORRECTLY, it has been....4 years since I did this.
Old Nov 23, 2018 | 01:07 PM
PurelyFord's Avatar
PurelyFord
Thanks, that's all I needed to know. Found another one for free that a coworker has that's in excellent condition and out of the truck
Old Nov 23, 2018 | 01:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different radiator supports used with round headlamps.
One was only used with the Super Cooling radiator, as it has a larger opening radius.
Super Cooling radiator measures approx. 26 1/4" wide x 24 11/16" high.
Standard, xtra cooling & A/C radiators measure approx. 26 1/4" wide x 19 3/4" high.
Old Nov 23, 2018 | 08:29 PM
PurelyFord's Avatar
PurelyFord
I'm glad you pointed that out. Thanks! I'll have to check mine and compare to the other one.
Old Nov 23, 2018 | 09:57 PM
1TonBasecamp's Avatar
1TonBasecamp
Maybe this is a good time to highlight the different mounting points for the radiator as well.
I don't know if it was a year-specific thing, or a radiator-size thing, but there were two styles of radiator flange mount during that time.
What was the criteria for getting one or the other? Super Cool vs regular, or something else?
I've had two of the large radiators with each one having the different style, so if not that way from the factory, at least the aftermarket radiators came both ways in the large size.
Thanks
Paul
Old Nov 27, 2018 | 04:57 AM
four-sixty-power
You can always cut the smaller radiator opening bigger, there are already 2 holes drilled on the driver side near where the new opening cut will be made, these 2 holes are the new mounting/bolting points for the larger radiator.
YES there is a difference in the radiator mounting, that being what was pointed out, and/or it may have been done to use up "old stock" from the factory floor. The rad either bolts directly to the rad support, or bolts to a spot-welded upright on either side of the rad support air flow opening. Actually it may have been size for the super cooling as I remember not being able to get a socket extension between the rad and the upright. Idk, iirc, ymmv, wysiwyg.
Old Nov 27, 2018 | 09:14 PM
john81chevy's Avatar
john81chevy
I just did the headlight thing with a 78/79 support onto a 77. I had to drill 4 new holes for each side. None of the original holes lined up. It was not difficulty to accomplish with a good drill, and a die grinder to elongate the holes for adjustment purposes.
Old Nov 28, 2018 | 03:03 PM
Justin73supercamper's Avatar
Justin73supercamper
I just did the same thing. My headlights are angled down too far and cant adjust them high enough for a good low beam distance without them pointing way to low. I'm going to look into shiming them up a bit
Old Nov 28, 2018 | 03:15 PM
brian1080's Avatar
brian1080
Pre-78 support vs 78 support with round headlights.
Old Nov 28, 2018 | 03:17 PM
NumberDummy
D8TZ-16138-A .. Radiator Support-Use with Rectangular Headlamps / Obsolete - 1978/79 F100/350 & Bronco.
The area behind the headlamp buckets is dished inwards, so the headlamps will fit correctly.
The two round headlamp supports do not have this feature.
blk450er
18
Jun 6, 2017 04:50 PM
warpaint
Feb 25, 2009 09:56 AM
mlevario99
Apr 3, 2008 04:01 PM
diablosport76
Jun 1, 2006 03:59 PM
FE427TP
Jun 20, 2001 08:56 AM
