78 headlight change
Old Feb 25, 2009 | 08:50 AM
warpaint's Avatar
warpaint
78 headlight change
Hello. What will I need, to change the headlights, from the square type to the round ones? All help would be appreciated.
Old Feb 25, 2009 | 09:48 AM
mad_jack's Avatar
mad_jack
just did this swap, but the other way around 76' to 78-79'. i have all the leftover parts, btw. there is a good thread on this if you do a search under "grille". the only major part difference is a smaller plate above the headlights which mounts to the radiator support. the 78 is larger and the headlight bracket mounts to it where the earlier plate bolts to the radiator surround itself. of course the headlights are lower and the signals above in the earlier models. i believe you'll need to drill out two holes, possibly four, to mount the headlight brackets though it's not too difficult to get the placement.
Old Feb 25, 2009 | 09:53 AM
mad_jack's Avatar
mad_jack
found the thread--give this a try!
https://www.ford-trucks.com/forums/8...ghlight=grille
Old Feb 25, 2009 | 09:56 AM
75F350's Avatar
75F350
Are you still using the 78/9 grille only to change the buckets from rectangular headlights to round style???? This only requires the bolt in change of the buckets and headlight suround.
If you are changing the entire grille to the 73-77 grille, then you will have a little drilling on the radiator supprt to do, but this is an easy swap.
gmeff
1997 - 2003 F150
Mar 10, 2010 06:53 PM
randomhero1172
Feb 24, 2008 09:29 PM
rock31
May 29, 2007 09:11 AM
77_f250_460
Paint & Bodywork
Dec 5, 2001 08:22 PM
