Need Help with ABS problem
Old Nov 20, 2018 | 08:54 PM
Dtgl1's Avatar
Dtgl1
I have a 2000 V10 w 90k. First the ABS light came on, then the Check Engine Light came on, next The Speedometer Stopped working, then the Overdrive Off light on the transmission shift stalk blinks on and off. All happened on the same day with in an hour or so. Any ideas? Thanks in advance for the help.
Old Nov 21, 2018 | 09:16 AM
alloro's Avatar
alloro
Sounds to me like an issue with the Output Shaft/VSS (Vehicle Speed Sensor).
Old Nov 21, 2018 | 09:35 AM
unleashd's Avatar
unleashd
Can you please pull up the codes and post here? That should give some ideas.
Old Nov 24, 2018 | 06:26 PM
Dtgl1's Avatar
Dtgl1
Thanks for the responses. Grandkids showed up for Thanksgiving, finally got to the code today. P0500 , which is the Vehicle Speed Sensor A. Looks like alloro was right. Confirmed by unleashd call for the code. I will get the part and put it in. Anything I should know about in the replacement process. I assume it’s on the transmission.
Old Nov 24, 2018 | 06:32 PM
Dtgl1's Avatar
Dtgl1
Looks like location is rear differential.
spinella
Jun 22, 2011 01:24 PM
PW01
1983 - 2012 Ranger & B-Series
Feb 20, 2006 01:07 PM
Smash15e
Feb 2, 2005 06:23 PM
Drewk77
Oct 18, 2003 02:04 PM
1999XLT
Oct 12, 2003 01:59 AM
