CAI 6.7
Old Nov 23, 2018 | 02:25 PM
  #46
82_F100_300Six's Avatar
82_F100_300Six
Originally Posted by honda250xtitan
opcorn: you need a snorkel and stacks for the most gainzzzzzz
We have a winner
Old Nov 23, 2018 | 02:28 PM
  #47
82_F100_300Six
Originally Posted by Strokin-A-2010
and my truck is nearly two years old so I wouldn’t say it’s new.
to me you truck is "new". But I still think Brian Johnson is the new singer of AC/DC. And Neal Peart is the new drummer for Rush.
Old Nov 23, 2018 | 05:06 PM
  #48
NCMillwright's Avatar
NCMillwright
ok well I’ve decided not to invest in a CAI. Sorry for underline idk... but how do people feel about full deletes on the 6.7? I will be tuning the truck obviously. I just don’t understand the point of fed regulated emissions that from my understanding do more harm to the motor than benefit it
Old Nov 23, 2018 | 05:22 PM
  #49
HMinus's Avatar
HMinus
To be perfectly clear, I DO NOT wish to get in a urination competition with anyone in this forum, but I have some questions with regards to the argument that the current generation of Power Strokes are such highly-tuned and exacting-in-tolerance vehicles and that a modification to the CAI is doomed to failure and/or a waste of money. Again, it is not my intent to call anyone out, as I am the first to admit my own ignorance. But, what I am not following in this argument is how a factory intake, which to my knowledge has no moving parts or adjustments being made by the truck's computer within the confines of what is being discussed regarding a swap-out, account for the difference in air density and oxygen content at sea-level, 90F, & 95% humidity versus 6000ft elevation, 20F, and 5% humidity. From my point of ignorance, a CAI that increases airflow would be beneficial in the latter example. What aspect of the 6.7's performance/operation am I missing that makes that assertion to be false?
Old Nov 23, 2018 | 07:48 PM
  #50
C12H24's Avatar
C12H24
Originally Posted by HMinus
...But, what I am not following in this argument is how a factory intake, which to my knowledge has no moving parts or adjustments being made by the truck's computer within the confines of what is being discussed regarding a swap-out, account for the difference in air density and oxygen content at sea-level, 90F, & 95% humidity versus 6000ft elevation, 20F, and 5% humidity. From my point of ignorance, a CAI that increases airflow would be beneficial in the latter example. What aspect of the 6.7's performance/operation am I missing that makes that assertion to be false?
Density altitude is compensated for by regulating turbo boost. The intake system monitors air temp and air mass so it has a pretty good idea about the density of the air going in. This is a pretty universal method with OEMs where boost is involved, not just Ford. As was mentioned above, this is why many modifications are without a positive result unless you use a tune to unlock torque management.
I would also like to add there is a scientific method to determine how restrictive your intake system may be. All you have to do is shove a 1/8" nylon tube in the intake pipe roughly half way between the air box and the turbo. Put a vacuum gauge on the line and read engine vacuum. To get a good indication, you would drive the vehicle to where you can put a load on the engine and lock out the trans. Floor it from torque peak to horsepower peak and observe the vacuum gauge (actually, unless you can data log, it would be better to have a co-pilot monitor the vacuum gauge). A system operating with zero restriction would show 0"hg. There aren't many systems not bred for the track where you would see zero. After all, the air filter itself is going to pull some vacuum in the tube ahead of the turbo. You start seeing restriction at around 3"hg. I'd like to tell you at what measurement you would be looking at some modifications but I don't have diesel performance expertise. But, again, if the system is allowing the turbo to deliver full boost at a density altitude, then having more or denser air available isn't going to pass the turbo.
Old Nov 23, 2018 | 07:59 PM
  #51
Hoss416's Avatar
Hoss416
Exactly why I asked my question Wrvond.
Old Nov 23, 2018 | 08:11 PM
  #52
BillyE's Avatar
BillyE
You can change it. Expect a good bit more intake noise, which might be good or bad, depending on what you’re going for. I’ve seen CAIs that gain HP and some that lose HP. It depends on pressure drop and how cold the air actually is that it draws. I’d look for 3rd party tests to confirm the HP gains. The stock airbox is pretty decent. No, you don’t need a tuner to “unlock” anything, although a tuner can increase the flow by increasing the boost and then a higher flowing airbox becomes more beneficial. Good luck. If you install one, please post a review. 👍
Old Nov 23, 2018 | 08:18 PM
  #53
Hoss416's Avatar
Hoss416
My engine wasn’t blown so you might want to learn facts before speaking retard.
Old Nov 24, 2018 | 07:51 AM
  #54
HMinus's Avatar
HMinus
[QUOTE=C12H24;18322908]Density altitude is compensated for by regulating turbo boost. The intake system monitors air temp and air mass so it has a pretty good idea about the density of the air going in. This is a pretty universal method with OEMs where boost is involved, not just Ford. As was mentioned above, this is why many modifications are without a positive result unless you use a tune to unlock torque management.
Thank you for the explanation. It now makes sense to me.
Old Nov 24, 2018 | 08:51 AM
  #55
C12H24's Avatar
C12H24
I should add that as diesels are throttled by fuel, the torque management strategy may include or be exclusive to the fuel management side. Meaning that even if there is more air available, the computer would or could trim fuel.
Old Nov 25, 2018 | 06:43 PM
  #56
Strokin-A-2010's Avatar
Strokin-A-2010
Originally Posted by 7591250sd
Be an adult, people are only trying to help the OP make a informed choice, name calling isn't needed.!!!!!
Sensitive much. Stop being a snowflake cause I called someone a name. I bet you were the kid that snitched on everyone weren't you.
Originally Posted by wrvond
You're right, it was somebody else, yours was only replaced. What a huge boost to your credibility! Which is only enhanced by your childish response.
I'd be insulted if your opinion had one shred of value.
So I'm not.
And you're response wasn't childish? And sorry you don't like my opinion, I only speak the truth. So I'm sorry you didn't like my truthful childish response since you didn't know the facts.
Old Nov 25, 2018 | 06:54 PM
  #57
HRTKD's Avatar
HRTKD
I don't know the finer details of how incoming air is processed in a diesel. In my prior half ton N/A gas truck, a CAI seemed to help some, but the overall effect was limited by the size of the throttle body which became the choke point once the intake filter, box and tube were opened up. The throttle body was drive-by-wire so the computer could easily limit the amount of air going into the intake manifold simply by closing the butterfly valve on the throttle body.
From the verbiage posted earlier in the thread by the aftermarket manufacturer, it wasn't clear to me if the HP/TQ gains were with or without a tune.
Old Nov 25, 2018 | 07:03 PM
  #58
Hoss416's Avatar
Hoss416
Umm you still haven't posted a link to your screen shot.
46Whizzer
Jan 17, 2016 10:00 PM
cbzdel
Modular V10 (6.8l)
May 18, 2012 10:27 AM
Sharky146
Sep 13, 2010 05:21 AM
My Ford
28
Apr 13, 2009 10:05 PM
yamaha500ml
2004 - 2008 F150
Aug 22, 2007 12:49 PM
