CAI 6.7
Old Nov 20, 2018 | 07:38 PM
NCMillwright's Avatar
NCMillwright
CAI 6.7
what manufacturer of CAI and model have had the best results or are best for 17-18 6.7l
Old Nov 20, 2018 | 07:48 PM
Tom N OH's Avatar
Tom N OH
Not worth the money. The stock system is fine.
Old Nov 20, 2018 | 09:02 PM
7591250sd's Avatar
7591250sd
You need to understand engine physics/tuning before wasting money.
Old Nov 20, 2018 | 09:23 PM
NCMillwright
Tuned my 14’ 5.0 f150 with sct... datalogged the truck according to what I had changed (CAI, intake manifold, headers, exhaust, cams, gears, tires, etc) emailed it in and received new strategies for what I was wanting out of it. This is my first diesel so perhaps you can explain the basic concepts behind them and tuning them for me?
Old Nov 20, 2018 | 09:38 PM
Sonny Crockett's Avatar
Sonny Crockett
You probably need a tune for the CAI to make a difference but I don't see many tunes or many people tuning the 6.7.
Old Nov 20, 2018 | 10:15 PM
blueiron's Avatar
blueiron
What exactly are you looking for with a CAI? HP? Torque? Increased engine noise?
An engine is a holistic system. If you change one variable, you have to alter other variables to compensate and that costs money in engineering, labor, and parts. Make certain that the manufacturer selling you these parts is guaranteeing you an specific increase in HP, TQ, or both as proven on an independent dynamometer. Otherwise, you are paying for their marketing in unprovable and unrealized "seat of the pants" results.
Old Nov 21, 2018 | 06:22 AM
fortheford's Avatar
fortheford
CAI is about as effective as rubbing snake oil on your turbo. Spend your money on something else.
Old Nov 21, 2018 | 08:26 AM
Busa 1 Dave's Avatar
Busa 1 Dave
On this specific application the CAI is a waste of money. If it were not I would have put one on from day one which is my standard operation in modifications but the testing does not bear out the increase in costs of a CAI. Do some research you will see.
Old Nov 21, 2018 | 09:54 AM
Strokin-A-2010's Avatar
Strokin-A-2010
A lot of misinformation in this post. A CAI on a N/A engine is pretty much a waste of money unless you're looking for looks and somewhat sound. On a engine that has a turbo or S/C it does make a difference. First thing I did to my truck was a Absolute Performance CAI and it does make a difference. It doesn't throw you in your seat or anything but it does help with the turbo lag and does gain some mpg, 1 at the most. And you do gain hp and tq from it. And no you don't need any kind of tuning if adding just a CAI.
Old Nov 21, 2018 | 09:55 AM
Strokin-A-2010
LMAO you might want to do some research and you'll see you're wrong.
Old Nov 21, 2018 | 10:18 AM
7591250sd's Avatar
7591250sd
Unless you do something to increase the VE ( volumetric efficiency ) - higher compression, higher lift/duration cam, better free flowing exhaust, A CAI will not help, and unless the VE & AFR tables are tuned, it is not possible for a CAI to have a significant effect on power..
Old Nov 21, 2018 | 10:21 AM
Strokin-A-2010
LOL.....ok
Old Nov 21, 2018 | 10:33 AM
CBEllis's Avatar
CBEllis
I don’t see any help for the OP. How many people have “wasted” money on these trucks? Almost everyone picks a place to spend, improve, customize.
My “wasted” money’s riding on the S&B model CAI that swaps the battery & air-box location. I’ll have one installed with no tune by Jan 1st.
Research that one and spend away!
Old Nov 21, 2018 | 10:40 AM
Strokin-A-2010
S&B is a good brand of CAI as well.
Old Nov 21, 2018 | 10:44 AM
Clubwagon's Avatar
Clubwagon
Lots of "wrong" here. The days of easy gains from less restrictive intake or exhaust systems is long gone. That is, unless you want to compromise the system's capabilities.
Given the HP/TQ wars between the big 3 truck manufacturers if it was as easy as changing the airbox and feed to the intake manifold to increase net HP/TQ, don't you think Ford would have already done that? The engineering investment Ford put into those parts is well beyond what the aftermarket can do. Perhaps some of these "CAI" provide a few more HP/TQ than the OE setup but at what cost? The OE system already draws air from an outside source.
Most of these systems change the filter element and that's where much of the gains come from. I am not willing to gamble the health of my engine on a few extra HP when the truck's stock output is far more than I can use 99% of the time. YMMV.
