E4od problem
Old Nov 18, 2018 | 02:04 PM
wahlturfcare's Avatar
wahlturfcare
E4od problem
I posted in another thread but thought I'd try this one too.
i have a '90 superduty with a 7.3 and the tranny was rebuilt a yr ago by a great shop and Dyno ran. I have had pretty much no problems except after I went to leave a property and I first had to jump the solenoid ( sometimes to start it you have to hold the key over and mover the shifter towards park quickly as I think the module on the column is bad) and when I went to leave I couldn't get the drive gear to shift out of first. But the other gears work if you select them. No flashing od light, only could I could get was a 67.
Fluid is full, clean and not burnt.also my speedo gear in the parking brake assembly on the tranny stoppps working over a week ago but ran and shifted fine.
Did I maybe break something in the column while trying to rock the shifter up to start it?
Old Nov 18, 2018 | 02:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Sounds like your range sensor is out of adjustment. Set your e-brake and put the trans in N,then remove the sensor,line up these marks and install with the trans in the N position.
Old Nov 18, 2018 | 03:12 PM
wahlturfcare
I checked that and it the marks were lined up
Old Nov 18, 2018 | 04:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Try starting it in N instead of park. Does that work?
Old Nov 18, 2018 | 04:27 PM
wahlturfcare
Right now I'm more worried about it not shifting out of 1st gear while it's in drive. And 2 gear works when you select it and first gear. But while in drive it stays in first and won't go to second or 3rd like it should.
Old Nov 18, 2018 | 05:15 PM
FORDF250HDXLT
Yeah,it's probably a bad sensor then.
Old Nov 18, 2018 | 05:48 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I would refer the OP back to post #2. If the transmission doesn’t know what gear is selected....
If I recall there are either voltage or resistance readings you can check for each gear position to verify MLPS operation.
Old Nov 19, 2018 | 04:39 AM
FORDF250HDXLT
Yeah,that's right. He can test it if he wants using this.
hmm.Well that's not so easy. Here's a zoomed in part of the section ya need.
wahlturfcare
Nov 18, 2018 04:52 PM
2fifty
Aug 4, 2017 01:37 PM
techningeer
Jan 14, 2014 08:41 PM
robr0924
16
May 25, 2011 09:45 PM
mmacsek
Jun 18, 2005 05:10 PM
