E4od drive is 1st gear....
Old Nov 18, 2018 | 12:06 PM
wahlturfcare's Avatar
wahlturfcare
I have a '90 superduty with the 7.3 idi and a rebuilt e40d that has been running great for over a yr. But today I went to leave a property and my drive gear seems like it is stuck in first gear and won't shift. 2nd and first both work on their own.
but before I noticed this I went to start the trick and I usually have to lift the shifter arm up and move it to get the key to crank(I think a bad shift module on the column is why). Could I have messed something up in the column?
The fluid doesntd smell burnt, is full, shifter arm with the adjustment sleeve doesn't look like the bolt slid around. Also, my spedo stopped working about 2 weeks ago( green one in the parking brake assembly on the back of tranny).
Any ideas guys could think of?
Old Nov 18, 2018 | 01:09 PM
wahlturfcare
Also, I checked and am only getting a code 67 on my scanner in keo mode
Old Nov 18, 2018 | 04:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think your TRS has failed. Replace it. It's the part on the driver's side of the transmission, with the wire harness attached.
Old Nov 18, 2018 | 04:52 PM
wahlturfcare
I will change that in the morning and let you Know.
gcashs66
Nov 23, 2020 09:09 PM
wahlturfcare
Nov 19, 2018 04:39 AM
Encho
19
Feb 20, 2016 02:26 PM
Toplait
29
Aug 20, 2014 02:03 PM
DarylZ
Jan 10, 2006 10:00 AM
