Accelerator Pump
Old Nov 15, 2018 | 08:31 PM
Rollie 1's Avatar
Rollie 1
Accelerator Pump
I have a 1985 F250 7.5L and continue to have a problem with the accelerator pump gasket dripping fuel. I replaced the whole assembly about 5 years ago and it has started once again. The 4 screws are as tight as I dare for fear of breaking them off inside the body. Would double gaskets work? Or could you use Permatex 2A on the gaskets?
Old Nov 15, 2018 | 11:05 PM
Tedster9's Avatar
Tedster9
The cover plate or whatever it's called might be warped. Can try using a piece of emery paper on a square of plate glass and sanding it down a bit getting it absolutely flat. Sealants that will hold up to gasoline over time are hard to find, though there are some. Worth a try.
Old Nov 17, 2018 | 09:35 AM
beartracks's Avatar
beartracks
Are you sure it's not the bowl or metering block gasket?
Merlyn James
Mar 22, 2018 01:55 AM
brooksbronco17
26
Feb 26, 2013 09:14 AM
my93
Mar 31, 2009 10:12 PM
doctorolds
Jun 26, 2007 05:02 PM
M6EV139445
Nov 28, 2006 09:40 PM
