Fuel pump gasket
Old Mar 20, 2018 | 10:27 PM
Merlyn James's Avatar
Merlyn James
Fuel pump gasket
I just finished installing a new fuel pump, it came with 2 gaskets but no instruction.... I only used one gasket and now it is leaking oil where it is bolted to the engine. Should I use both gaskets? Rtv?
Old Mar 21, 2018 | 12:12 AM
Tedster9's Avatar
Tedster9
For whatever reason have never bothered with gasket sealer on fuel pumps and have never had a problem. Be really careful with RTV, just a skim coat. Excessive use could flake off internally and end up plugging internal oil galleries or oil pump pickup, don't want that.
Old Mar 21, 2018 | 10:39 AM
jakeharp's Avatar
jakeharp
RTV
With these old motors, there is pitting and surface inconsistencies everywhere.... A thin coat of RTV on both sides of the gasket is what I recommend for just about everything .... And I hate cleaning old RTV as much as the next guy, but hoping everything seals with just a gasket on a 40 year old motor, is just hoping.... I only remember getting one gasket with my fuel pump...
Old Mar 21, 2018 | 11:31 AM
Merlyn James
I assumed on was just a spare, but maybe I was supposed to use both? They were pretty thin.. It was a pain in the *** to get up under and scrape all the gasket off, so I wasn't able to get in with a die grinder and condition the surface like I wanted too. Even putting the bolts back in was difficult because the power steering pump was in the way. Im putting in new timing gears and water pump next so when I get some of that out of the way Ill give it a pass with the die grinder, try to reduce some of the consistency and try again...
Old Mar 21, 2018 | 11:58 AM
stroken7.3's Avatar
stroken7.3
I replaced my fuel pump a month ago on my 400, it didn't have a gasket or silicone and didn't leak. My new pump came with 2 gaskets also but I only used one and so far so good.
Old Mar 21, 2018 | 12:23 PM
Tedster9's Avatar
Tedster9
In this case 2 gaskets aren't twice as good.
Old Mar 21, 2018 | 01:54 PM
niko20's Avatar
niko20
Don't use RTV, jesus H. People use that stuff way too often
Get something called Gasket Sealer or Gasket Shellac. I found Gasket Shellac to work awesome. Orielly's has it
Old Mar 22, 2018 | 01:55 AM
burnthelight88's Avatar
burnthelight88
Definitely not supposed to use 2 gaskets against each other...
jmug23
Dec 18, 2017 07:48 PM
brooksbronco17
26
Feb 26, 2013 09:14 AM
desoto dave
1983 - 2012 Ranger & B-Series
Dec 6, 2010 06:18 PM
M6EV139445
Nov 28, 2006 09:40 PM
ba 302
1978 - 1996 Big Bronco
Apr 4, 2003 11:05 PM
