Clutch Pedal Removal
Old Sep 26, 2003 | 04:17 PM
philipwhite's Avatar
philipwhite
Howdy,
I've got a '73 F250 4x4 and I'm trying to figure out if there is an easy way to remove the clutch pedal. It seems like there should be someway to do it without removing the brake booster and pedal.
Thanks,
Phil
Old Sep 26, 2003 | 04:30 PM
grapegravy's Avatar
grapegravy
The pedals have to come out together, just unhook the control levers and loosen the shaft assembly. They'll come right out
Old Sep 26, 2003 | 05:40 PM
philipwhite
Hi,
Thanks for responding! What's the best way to loosen the shaft assembly? Are you saying the pivoting bar will slide out through the bracket? I'm not sure I fully understand.
Old Sep 27, 2003 | 01:40 AM
grapegravy's Avatar
grapegravy
Should be sitting on bushings on the support bracket, pop them out and then the whole assembly
Old Sep 27, 2003 | 10:41 AM
stargazer's Avatar
stargazer
hey Philip,
the clutch pedal will be the last thing to come of when you slide the shaft out that holds the brake pedal also. you can just let the brake pedal hang on the pushrod for the booster until you're ready put it back together. if I remember right the automatic trucks had a bolt for a pivot and the manual trucks used the clutch pedal with the shaft as part of the pedal.
it can be fun upside down under there getting it all aligned again without trashing the bushings, but its not too bad.
i hope this is what you need, not sure exactly if your removing the entire bracket or just the pedal itself?
Old Sep 27, 2003 | 10:51 AM
philipwhite
Hey Will,
How is it going?
I'm just trying to remove the pedal itself. I need to weld something onto it for my hydraulic clutch. I'm just about to go out and take a look at it right now. Is there any trick to removing the shaft?
-Phil
Old Sep 27, 2003 | 12:52 PM
GeneStoner's Avatar
GeneStoner
Or you can cheat like I did when I did my Manual-to-Auto conversion--
Just hide the disabled pedal behind the carpet, you can barely see it.
Old Sep 27, 2003 | 12:54 PM
grapegravy's Avatar
grapegravy
Gene, he's putting a hydraulic clutch in, needs the pedal. It comes out very easily, waiting for him to actually look at it
Old Sep 28, 2003 | 02:16 AM
philipwhite
Yeah I got it out. It was pretty easy, except for the spring. The whole time I just didn't realize that what I was looking at was an e-clip. I also managed to break that clip removing it , but thats ok.
Thanks for the help, fellas.
emeraldcoupe
Jan 23, 2015 03:34 PM
4inchlovin
Feb 24, 2012 05:06 PM
Schmitty
Sep 23, 2010 09:09 AM
pigskin
Jul 8, 2004 11:28 AM
51dueller
Jun 1, 2003 11:14 AM
