I haven't dug into it yet, but can you remove the clutch pedal from the hanger or do I need to find a hanger with just a brake pedal? my truck was a three on the tree, going with an auto.
You can just unbolt and pull out but you will have to rig up a bolt/ bushing setup to fill the space inside the brake pedal pivot. Be careful clearing the under dash wiring when you pull it out.
