Only run choked
Old Sep 27, 2003 | 09:09 AM
RJOLLEY's Avatar
RJOLLEY
Only run choked
Problem: 1973 F350, with 390 motor. Engine will only run with choke fully enganged. Have replaced Carberator, changed intake manifold gasket, same problem exists. Any ideas what to check next?
Old Sep 27, 2003 | 09:54 AM
sparky's Avatar
sparky
Kind of sounds like a vacuum leak........engine is getting too much air.....so it runs too lean....close the choke reduce airflow into carb and it runs....possibly a broken vacuum line or a leaky carb gasket.
Or how about the idle/mixture screws being set too lean? Or plugged fuel jet in carb?
Old Sep 27, 2003 | 01:37 PM
grapegravy's Avatar
grapegravy
Did the carb you changed come out of a box, or was it used?
Old Sep 28, 2003 | 04:33 AM
macguyver's Avatar
macguyver
PCV valve (missing, big vacuum leak)? Brake booster vacuum leak? Just some more ideas.
Rusty_S
Dec 12, 2012 02:24 PM
$Simpleman76
Apr 22, 2007 11:46 PM
muddyforeman
Feb 16, 2005 07:10 PM
WrenchHead84
16
Jan 9, 2002 10:00 PM
brown 4x4
Apr 5, 2001 05:29 PM
