Head Studs
Old Nov 15, 2018 | 09:24 AM
oldbird1965's Avatar
oldbird1965
Originally Posted by fordpride
Glenn you should alway re-torque after a couple heat cycles.
ooopppppp!
Old Nov 15, 2018 | 10:16 AM
fordman67's Avatar
fordman67
Cause its so much fun the first time in the vehicle..
maybe before I drop my cab on the final time I should put the torque wrench on a few . I doubt much will be had honestly.
Old Nov 15, 2018 | 11:13 AM
fordpride's Avatar
fordpride
I got about a 1/8 of a turn just form mine sitting a couple days never being heat cycled and another 1/8 to 1/4 turn after a heat cycle.
Old Nov 15, 2018 | 11:37 AM
dclack's Avatar
dclack
Originally Posted by knottyrope
irate says when hitting 40 PSI boost or over stage 2 injectors
https://www.iratediesel.com/irdie/pr...head-stud-kit/
Riffraff still has them cheaper... https://www.riffraffdiesel.com/arp-7-3l-headstud-kit/
Old Nov 15, 2018 | 04:35 PM
427 fordman's Avatar
427 fordman
Glenn, I'd for sure check them means you are in there, and go with arp numbers. They should always be checked on a new motor. I wouldn't sweat it much on a motor that had a lot of miles on it already and they were just swapped in. I never did.
Old Nov 15, 2018 | 07:50 PM
oldbird1965
Yeah, I will check them Darin. Last summer after I sent Jim the injector that was supposedly bad he asked me to check the oil spouts next time I'm in there. He said that the injector had the oil spout on it and he never gets injectors with the oil spout on them. Sure enough, that so call mechanic put the injector in without a oil spout. Jim is mailing me one. In talking to him he also said to check the torque. He also said with a new motor there should be a new copper washer on the injectors. I pulled them I can't tell if they were new so I ordered a new set of O rings and washers from Clay. I wasn't going to pull the injectors in doing the shims but oh-well, Fun Fun!
Old Nov 15, 2018 | 11:46 PM
Hit Man X's Avatar
Hit Man X
Ah the old 'while I am in here...' syndrome! . I fell down that rabbit hole over the summer when building my trans. The fruits of my labor were well worth it in the end.
At least you checked on the injector. Missing a part is sad :/ could it have caused any damage? You sure you have the hardened pushrods? My Smith Bros were not marked.
How were the heads in terms of shims required for proper install height of those springs?
Agree 100% to recheck stud torque.
Old Nov 16, 2018 | 08:34 AM
oldbird1965
I haven't checked the valve height yet. I would not think the missing oil spout would cause a problem? I'm sure if it would cause a problem Jim would have said so. As far as the pushrods, they are nice and shiny silver including the ends. I don't have a stock one around but I think I read that one end of the stock one is copper colored?
Old Nov 16, 2018 | 09:57 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Yes, I do recall the SB pushrods being much shinier. Probably have pics in my thread!
bkks744
Jun 29, 2010 05:08 AM
satwood
Dec 29, 2009 09:07 AM
IanR
Mar 18, 2008 03:46 PM
santacruzf250
Jul 9, 2007 10:27 PM
bcford6.9
Apr 19, 2006 10:04 PM
