Buzz test injectors before installing them?
Old Nov 13, 2018 | 10:15 AM
dentvet's Avatar
dentvet
Most of my injectors buzz very weakly so I picked up some used, cheap but supposedly good used injectors with 130K miles. i'm thinking of getting a new valve cover gasket and doing the buzz test on them before I install them. Is this possible or do they have to be grounded, etc? Just trying to save myself the work of replacing bad injectors with bad and I could theoretically return the used injectors for a refund if I find them bad....
Old Nov 13, 2018 | 12:16 PM
axmrdr's Avatar
axmrdr
To complete the circuit I'd say that they must be grounded at some point. I'm not a diesel expert but I am an electrician. They are going to vibrate I would imagine so ground them at a point that a small arc burn won't interfere will a machined fit.
Old Nov 13, 2018 | 12:50 PM
Chevota_72's Avatar
Chevota_72
They have a power wire and a ground wire so they dont need to be grounded themselves. Not sure how accurate of a test it would be, but I guess if there was a major difference in sound with one it may indicate an issue.
Old Nov 13, 2018 | 03:17 PM
axmrdr's Avatar
axmrdr
You're right, don't know what I was thinking. As a matter of fact aren't they fed a high voltage? 110 volts or something like that
Old Nov 13, 2018 | 06:51 PM
SaintITC's Avatar
SaintITC
At a minimum of 110, 120Vdc if newer. The buzz test only powers the solenoid and lifts the poppet valve. It has no effect on the rest of the injector when there's no high pressure oil applied to them. So you won't be testing the movement of the plunger or needle.
This is a good question. I now wonder why they buzz, it's not like the poppet valve is oscillating up and down during the test. Or does it?
Old Nov 13, 2018 | 09:03 PM
DieselDenny's Avatar
DieselDenny
I think it just shows sel action. I can't see a mechanical reference. Kinda like a system happy check where your getting correct voltage and ohms to the unit. Unsure tho? Good quest.
Denny
Old Nov 15, 2018 | 07:05 AM
dentvet's Avatar
dentvet
my impression is that the solenoid is turned on and off rapidly which flutters a valve. The seat of the valve wears over time so "poppet valve armature clearance" is reduced. the worn valves flutter less so they don't make as much noise as unworn ones as they buzz or slam back and forth? I don't have a great understanding of the process, though. hence my questions.
I did run across this kit which includes a bunch of spacers that will somehow adjust the clearances inside a worn injector. I think its all related to what is going on with a buzz test in general.
https://www.ebay.com/itm/7-3L-POWERS...9321ecffe73d8c
Old Nov 17, 2018 | 09:14 AM
MoBill122's Avatar
MoBill122
Papa Smurf
I did the kit 150,000 miles ago.... now approaching 480,000.... original injectors... Getting 17-17.5 mpg, but its just a daily driver. Always thought when I get to 500,000, I'll get new injectors for the beast.
Old Nov 30, 2018 | 05:05 PM
dentvet's Avatar
dentvet
Well I hooked up my used injectors to the wiring harness, just laying in the engine bay. At 32 degrees today, only one of the loose injectors buzzed. The other three loose and all four of the injectors on the other bank failed to buzz.
I measured the armature plate clearance on one of the original injectors and I couldn't get a .002 feeler under it. One of the "replacement" injectors had around .002. New clearance is supposed to be .004".
Old Nov 30, 2018 | 05:14 PM
beef tits's Avatar
beef tits
You can get a "budget rebuild" from Rosewood for $500. This will likely be a wayyyy better option than installing used injectors, unless you really enjoy frequetly pulling out inectors
1999.5 - 2003 AD Split Shot Injectors | Rosewood Diesel Shop of C******, OH
Old Dec 12, 2018 | 07:57 PM
dentvet's Avatar
dentvet
I ended up shimming the old injectors to restore the armature clearance from zero to .003 inches. Mostly because
i'm lazy but partially as an experiment. After shimming, all the injectors sound pretty good on the buzz test.
I started the engine without preheating it at below freezing temperatures today. I used to have to plug in the block heater even when it was 70 degrees outside to get it to start up. $75 for the kit $75 for a valve cover gasket and a few hours to install the shims seems to at least have solved my cold start issue.
I'm going to save the wiring off the old gasket so I can again buzz test injectors without them being installed in the engine. I still have 7 extra used injectors for future use.
Old Dec 13, 2018 | 05:18 AM
dentvet's Avatar
dentvet
Here is the shim kit I used. Comes with tools and instructions. Only requires pulling the valve covers and solenoids from the injector tops.
https://www.ebay.com/itm/INTERNATION...72.m2749.l2649
I found that my injectors had already been worked on. One was a different brand, had the most armature clearance, and sounds best on the buzz test. The other 7 had "ADP" scribed onto them and 3 were already shimmed. (4,6 and 7). cylinder 8 is failing the cylinder contribution test for some reason.
Old Dec 13, 2018 | 09:51 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Aside from starting how does it run and sound in various driving conditions ?
ive been wanting to rebuild my own injectors mostly for the experience of it,
Bitterroot makes and sells the tool and all the parts.
https://bitterrootdiesel.com/collections/1999-2003-7-3-powerstroke
Here is a great video on the process
Old Dec 13, 2018 | 07:25 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
8 fails contribution test all the time, no worries. It is downstream fuel-wise from 6, which fires just before it. So 8 is always a bit starved on fuel pressure. 3 is another common fail on the CCT.
And thanks for posting up your results on the shim kit, good to hear it worked for you.
eatont9999
May 8, 2012 09:20 AM
97haymachine
Apr 17, 2010 11:39 PM
throwdown
20
Feb 19, 2010 07:12 AM
muddyforeman
28
Nov 1, 2009 06:37 PM
parrisw
22
Nov 25, 2008 08:10 AM
