can I test injectors before installing??
Old Nov 24, 2008 | 12:21 PM
parrisw's Avatar
parrisw
I'm finishing up my 7.3ps, and about to install the injectors, is there any test I can do on them before I put then in the heads. I'd hate to put this engine in the truck and then find out the injectors are bad.
Old Nov 24, 2008 | 01:35 PM
tjbeggs's Avatar
tjbeggs
pretty much no you can't. you can test the electrical solenoid with an ohm meter. They should read about 2.5 to 3 ohms and that is about it.
Old Nov 24, 2008 | 01:45 PM
parrisw's Avatar
parrisw
Ok, I'll just do that and hope for the best I guess.
Thanks
Old Nov 24, 2008 | 01:47 PM
AndysFords's Avatar
AndysFords
If I had my engine out I would send them off to be tested, most injection shops can either test them or they can send them off to be tested, normally about $35 a piece to test.
Old Nov 24, 2008 | 01:50 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I have read something about a "flow test bench" , is that what the first post asked or what is about it?
Old Nov 24, 2008 | 03:18 PM
Cuda_jim's Avatar
Cuda_jim
Yep Jose, but an injector flow bench is mighty expensive to own.
Like Andy said, most injector rebuild shops should have one if you think they need to be tested.
The place you got them from should have flowed them of they are a quality re-builder.
If you're doing a set of DIY'ers then I would definitely get them tested.
Old Nov 24, 2008 | 03:33 PM
AndysFords's Avatar
AndysFords
When my neighbor needed some tested he had to send them to South Mississippi, somewhere near Jackson, I think. No one had one in Montgomery or Birmingham Alabama
secondarychaos's Avatar
secondarychaos
Would RDS do that? and if so, how much?
he's sponsoring this section... hopefully he can tell us...
Old Nov 24, 2008 | 03:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Thank you Jim. But I dont think that all of the DIY´ers here in the forum have had them tested and I think they work well IDK. So they would but not MOST, am I right?
Old Nov 24, 2008 | 04:22 PM
Cuda_jim's Avatar
Cuda_jim
That's right but I don't like doing things twice. Not sure how many DIY'ers had trouble. Most of the install trouble comes form the o rings IIRC
Old Nov 24, 2008 | 04:38 PM
parrisw's Avatar
parrisw
what kind of troubles with o-rings?? Any tips on installing the injectors? I have new seal kits.
Old Nov 24, 2008 | 04:45 PM
maverick1701's Avatar
maverick1701
you get a mouth-full of diesel fuel then blow it through the injector to check the atmoization of the fuel
LMAO
Old Nov 24, 2008 | 04:47 PM
maverick1701
but seriously, in the AG shop on campus we have an injector tester...you stick in the injector on the instrument, full the tank w/diesel, pump up the tester then open the valve and it allows you to see the atomization of the fuel as the injector does its thing.
We have used it on a few tractors, my truck and another guys 6.blow and it has worked well
Old Nov 24, 2008 | 04:52 PM
Cuda_jim's Avatar
Cuda_jim
Just make sure the injectors are seated all the way down. I use a rubber mallet. If it's cocked going in you might nick an o ring. Use lube.
Old Nov 24, 2008 | 04:56 PM
TexasDiesel97's Avatar
TexasDiesel97
Wish our School Ag. Shop had one, would make life easier when rebuilding tractors.
