Need recommendation pls
Old Nov 11, 2018 | 07:35 PM
Rockinfigs's Avatar
Rockinfigs
I have the oem 5th wheel package on my 2019 f350...I'm planning on getting the Anderson ultimate hitch...but need a ball insert for the 5th wheel...which ball kit do u guys recommend...reese ,bw or curt?
Old Nov 11, 2018 | 07:48 PM
senix's Avatar
senix
use the OEM one. Reese makes it. You should be able to find it on amazon.
Old Nov 11, 2018 | 08:31 PM
Rockinfigs's Avatar
Rockinfigs
This one ?
Old Nov 11, 2018 | 08:33 PM
senix's Avatar
senix
that is what I have.
I run a reese 5th wheel, both I have the goose neck to run too for some trailers.
Old Nov 11, 2018 | 08:46 PM
Army RET's Avatar
Army RET
Be aware: if you use the AUH on a gooseneck ball (as I am) on top of the Ford puck system (as I am) then the remaining bed pucks are inaccessible - the AUH covers them. I don't see this as a problem - but you may. So purchasing either ball kit (shown above) that provides tie-down capability to the (now covered) pucks is wasted, just get the ball.
Three states DO require safety chains, if you're one of them Anderson provides a solution kit, selling the chains and an attachment plate that mount over the ball but under the hitch.
Going by memory (I haven't seen it in months) but I believe my removable ball is from Curt. As I didn't need the additional links they sold me the ball separate (then reordered one to replace the now missing ball).
Old Nov 11, 2018 | 08:56 PM
Rockinfigs's Avatar
Rockinfigs
Originally Posted by Army RET
Be aware: if you use the AUH on a gooseneck ball (as I am) on top of the Ford puck system (as I am) then the remaining bed pucks are inaccessible - the AUH covers them. I don't see this as a problem - but you may. So purchasing the ball kit (shown above) that provides tie-down capability to the (now covered) pucks is wasted, just get the ball.
Three states DO require safety chains, if you're one of them Anderson provides a solution, selling the chains and an attachment plate that mount over the ball but under the hitch.
Thks for heads up...I heard auh blocks the pucks so I'm going to get the Anderson safety chain plate that goes on the hitch ball
Old Nov 11, 2018 | 08:58 PM
Army RET's Avatar
Army RET
Old Nov 11, 2018 | 09:02 PM
Rockinfigs's Avatar
Rockinfigs
Ok do I need reese 19315 or 19311 ball…?
​​​​​​ I guess 19315 ball is with a riser. Will the Anderson fit the ball w riser?
Old Nov 11, 2018 | 09:07 PM
Army RET's Avatar
Army RET
As I'm not familiar with what the 'riser' offers I would ask the seller/dealer of your new hitch which ball(s) they recommend for use with the Ford puck system.
In my weakened mind I believe my dealer set me up with the Curt; was is because it was the best, or provided him the greatest profit, or simply what he had in stock?
All I can swear to is ... it works for me.
Old Nov 12, 2018 | 07:39 AM
orion1968's Avatar
orion1968
Andersen makes an adapter that fits over the ball that I use for safety chains. I am not in one of the states but feel a bit safer with the chains on.
PrinceValium
Dec 22, 2016 01:41 AM
uscgmkcret03
6.7L Power Stroke Diesel
Aug 15, 2013 09:21 PM
George D.
Mar 5, 2008 09:24 PM
RabbiBarr
All Things Towing
May 12, 2003 11:00 PM
chopperdude
Feb 17, 2002 11:50 AM
