Sponsored by: Auxito
Help!!!!!!
Old Nov 9, 2018 | 06:59 PM
Abear375's Avatar
Abear375
Help!!!!!!
Ok, so I need some help, my 30 amp ficm relay fuse works only when it wants, I can wiggle it and sometimes it'll work sometimes it won't, wanted the dealer I got it from put the fuse in it when I went to test drive it so I'm assuming they pulled the fuse in and out a few times since it was there for a while. 04 f250 6.0
Old Nov 10, 2018 | 07:16 PM
Bluegrass 7's Avatar
Bluegrass 7
Read your post!
You know what you mean but we don't what your talking about.
Old Nov 11, 2018 | 07:49 AM
alloro's Avatar
alloro
Originally Posted by Bluegrass 7
Read your post!
I think he's talking about the fuel pump relay and fuse.
Old Nov 11, 2018 | 08:28 AM
steve(ill)'s Avatar
steve(ill)
well, if you wiggle the relay and it starts working, then the pins on the relay are bent / corroded......... or the socket it pushes into is bent or corroded.
Old Nov 11, 2018 | 09:03 AM
Abear375's Avatar
Abear375
So it's the 30 amp relay, its grey, it controls the injectors and the glow plugs, I pulled to fuse and there's black marks on the relay prongs, looked all over for the relay fuse and no parts store has it, guess I'll have to go to Ford
Old Nov 11, 2018 | 01:04 PM
pdqford's Avatar
pdqford
Originally Posted by Abear375
Ok, so I need some help, my 30 amp ficm relay fuse works only when it wants, I can wiggle it and sometimes it'll work sometimes it won't, 6.0
Well, I *think* he’s talking about the fuse.
When he wiggles “IT”, sometimes IT works.
I see the ‘black marks’ on the relay blades in the picture, but are there marks on the fuse blades?
Old Nov 11, 2018 | 01:56 PM
Abear375's Avatar
Abear375
Not that I can see, I just had a buddy test the relay and he's not getting any signal from it
Abear375
Nov 9, 2018 07:00 PM
weyland426
Jun 27, 2014 03:09 PM
73f100shortbed
Bronco II
Jul 18, 2006 06:50 PM
