2018 F250 6.2L gas pump clicks off prematurely
This has been happening since my very first fill up (now has 2k miles on it). Whenever I go to get gas the nozzle clicks off numerious times before it’s fully filled up. Some gas stations as much as every 2-3 gallons. Any ideas??
Maybe a blocked or kinked vent hose somewhere?
Could be a blocked filter on the vent line?
Do you overfill the tank or do you normally stop once the pump shuts itself off? I had a similar issue with my F150 and I was told the inside of the vent filter collapsed, probaly from getting wet because of overfilling. Not sure if it would happen that quickly to you though.
I'd try and find the location of your charcoal filter. I think its above the spare tire, if I'm wrong someone else here will hopefully correct me. Its alot larger then you would think.
But honestly if it is that new I would take it in before trying to do anything yourself. No reason to have a dealership say it's not under warranty because you broke something.
I've had my 17' for close to a year and half now and I've noticed that when I run it down close it empty it seems to happen more than if I'm still around 1/4 tank. Also, it really only seems to happen when I first start pumping. After I get going it doesn't seem to happen. As was previously said the only thing I have been able to do to is just throttle back and let it fill on up.
pollockb
46
01-27-2015 09:16 PM
berry1234
06-01-2009 10:42 PM
53lakeside
02-20-2008 06:45 PM
