2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2018 F250 6.2L gas pump clicks off prematurely
Old 11-08-2018, 06:08 PM
adgjqetuo's Avatar
adgjqetuo
adgjqetuo is offline
This has been happening since my very first fill up (now has 2k miles on it). Whenever I go to get gas the nozzle clicks off numerious times before it’s fully filled up. Some gas stations as much as every 2-3 gallons. Any ideas??
Maybe a blocked or kinked vent hose somewhere?
Old 11-08-2018, 06:13 PM
Heathen Dave's Avatar
Heathen Dave
Heathen Dave is offline
Could be a blocked filter on the vent line?
Do you overfill the tank or do you normally stop once the pump shuts itself off? I had a similar issue with my F150 and I was told the inside of the vent filter collapsed, probaly from getting wet because of overfilling. Not sure if it would happen that quickly to you though.
Old 11-08-2018, 06:23 PM
adgjqetuo's Avatar
adgjqetuo
Not sure - it’s done it since my very first fill up at 300 miles so it’s hard to tell when it’s actually full vs false clicking off.
I was hoping to get some direction with places to look before taking it to the dealer.
Old 11-08-2018, 06:42 PM
Heathen Dave
I'd try and find the location of your charcoal filter. I think its above the spare tire, if I'm wrong someone else here will hopefully correct me. Its alot larger then you would think.
But honestly if it is that new I would take it in before trying to do anything yourself. No reason to have a dealership say it's not under warranty because you broke something.
Old 11-08-2018, 06:44 PM
TCNashville's Avatar
TCNashville
TCNashville is offline
Unfortunately this is a common problem and there are a number of threads about it. My '17 F-250 6.2 still does this occasionally and it's very annoying. What I do now is when it does it, I restart the pump and gently grab the fuel hose about a foot behind the nozzle and change the angle of the nozzle and let go of the hose and more times than not it fills the rest of the way without shutting off.
Old 11-08-2018, 07:11 PM
JackalAR's Avatar
JackalAR
JackalAR is offline
I filled up about 5 times after purchase at 8200 mi. and it worked perfectly. Went to top off (15.5 gal) yesterday and had to struggle with it.
Old 11-08-2018, 07:15 PM
Tankclimber18's Avatar
Tankclimber18
Tankclimber18 is offline
My first fill up was like this, but no problems since almost 7k
Old 11-08-2018, 08:44 PM
slip knot's Avatar
slip knot
slip knot is offline
My 2019 does this every now and then. Moving the nozzle in or out just a bit seems to help.
Old 11-09-2018, 08:57 AM
LadderDogV10's Avatar
LadderDogV10
LadderDogV10 is offline
Mine does it too. I just don’t insert the nozzle all the way. Try backing it out just a bit and try it that way. Mine doesn’t click off when I do it that way. I think the angle causes somewhat of a bottle neck when the nozzle is in bone deep.
Old 11-09-2018, 09:14 AM
JackalAR's Avatar
JackalAR
JackalAR is offline
When mine acted up, nothing short of throttling WAY back helped, tried all angles, even pull it completely out of the hole and shot it in.
Old 11-09-2018, 09:40 AM
Krabill's Avatar
Krabill
Krabill is offline
Mine does it too
Old 11-09-2018, 09:44 AM
GoldenDomer's Avatar
GoldenDomer
GoldenDomer is offline
I've had my 17' for close to a year and half now and I've noticed that when I run it down close it empty it seems to happen more than if I'm still around 1/4 tank. Also, it really only seems to happen when I first start pumping. After I get going it doesn't seem to happen. As was previously said the only thing I have been able to do to is just throttle back and let it fill on up.
Old 11-09-2018, 09:47 AM
GoldenDomer
Quote of the day.....
Old 11-09-2018, 09:57 AM
GoldenDomer
Nmaykdm
03-25-2019 07:47 AM
pollockb
46
01-27-2015 09:16 PM
berry1234
06-01-2009 10:42 PM
53lakeside
02-20-2008 06:45 PM
txwing
02-12-2004 09:32 PM
Quick Reply: 2018 F250 6.2L gas pump clicks off prematurely
