How to for kill switch...
Old Nov 6, 2018 | 05:57 AM
rtcapo's Avatar
rtcapo
I'll be back on the road soon with my '64 F100, and would like to rig a kill switch for some added protection when parked.
6 Cylinder, 3 speed manual...all stock.
Yeah, I'm a rookie mech, but I can solder and follow steps...with a little practice.
Any hints or links would be appreciated.
rtc
Old Nov 6, 2018 | 06:50 AM
dman2008's Avatar
dman2008
All you really need to do is put a toggle switch inline with the hot wire that goes to the coil so it doesn't allow the ignition to get spark. Hide it under the dash or in the glove box somewhere. There will be a stud on the ignition switch labelled I for ignition just put it inline with that, open the circuit no power, close the circuit power to complete path and allow truck to start.
D
Old Nov 6, 2018 | 07:59 AM
rtcapo's Avatar
rtcapo
D
nice...thanks
rtc
Old Nov 6, 2018 | 01:59 PM
cosmofennema's Avatar
cosmofennema
You may also wish to hide the switch in plain sight.
Get a small push-type on/off switch with at least a 10 amp rating.
Gut your lighter socket.
Mount switch in the lighter socket, then just push in the lighter before you start, and push again when you wish to kill the ignition.
Cosmo
Old Nov 6, 2018 | 11:03 PM
1965GTFB's Avatar
1965GTFB
Cosmo
I met a guy with an old Chevy truck and he converted the lighter to be the switch. Push it in, as you would to get it hot, and what it really does is complete the circuit to start the truck.
Old Nov 7, 2018 | 04:10 AM
FuzzFace2's Avatar
FuzzFace2
You could ground the negative side of the coil, the side the points are wired to.
With it to ground you also get no spark.
Besides if someone was to hot wire, power from battery + to coil + the truck would run bypassing your kill switch, not so with the negative side to ground.
Could add 2 switches and do both.
Dave - - - -
mountain dewd
Jun 29, 2016 03:15 PM
mudguts
Nov 28, 2014 10:30 AM
rob8210
Apr 1, 2013 05:40 PM
78ford4x4Bigred
Jul 9, 2012 04:47 PM
jat4
Aug 21, 2011 11:04 PM
