Front Clip Removal
Old Nov 4, 2018 | 06:24 PM
NW 150's Avatar
NW 150
Front Clip Removal
Well I need to yank the motor again and have it rebuilt. This time I will be doing it outside in the driveway so I'll be needing to remove the front clip to access the motor easier for removal. Does anyone have a step by step instruction on how to do this or does it matter? Just need to take off enough to pick up the motor out of the perches and pull it back out. Thanks!
Old Nov 4, 2018 | 09:01 PM
ranger140892's Avatar
ranger140892
Grumpy goat
I can't remember every bolt, but here goes. Remove or disconnect all electrical on the aprons. Don't forget starter cable, negative battery cable attached to block, lights, ICM, starter solenoid, voltage regulator. Remove the battery. Remove the hood, or you can leave it on. I'd remove it. Detach radiator hoses from engine. Remove the two body mount bolts up front under the core support. Remove the apron bolts (3 on each side). Now you gotta look for bolts. One is inside the door jams. One is under the truck just forward of the doors. And there should be rubber straps attached to firewall. Remove those bolts. There should be a ground strap from hood to firewall. I can't remember if there's another ground strap from fender/apron to firewall. I may be missing a couple, but you'll see them when you try to move the clip. The aprons, core support, radiator, grille, and fenders come off as a unit. Two men can lift it. And it'll be easier to pull the clip if your tires are Off.
Old Nov 5, 2018 | 01:05 PM
Aaron-71's Avatar
Aaron-71
Don't forget to remove the shock towers and disconnect the front brake lines (rubber hoses). The shock towers are much too tall to get the front clip off unless you + your helper have some serious muscle.
Brake lines should be removed because those pesky inner fenders are bloody sharp! My helper never paid attention, and he sliced open the brake line by dragging the front clip along the frame...
Old Nov 5, 2018 | 01:41 PM
ranger140892
Grumpy goat
Remove the shock shock towers?? They're not an obstacle during clip removal. I've never done that. Or the brake lines, though I understand that one.
Old Nov 5, 2018 | 02:11 PM
Aaron-71's Avatar
Aaron-71
Maybe it's just me then? Not sure, but I've always removed them.
Didn't remove them when pulling the front clip one time.... regretted it dearly.
Old Nov 5, 2018 | 08:12 PM
ranger140892
Grumpy goat
Ouch. Bend something? On reflection, I think you're right. A little extra work up front tends to make life easier during the job. True with most things in life.
Old Nov 5, 2018 | 09:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
ALWAYS ALIGN THE BODY PANELS! before you remove them. A shapie mark on the underside of the hood where the hoonges mount and where the inner fenderwell aprons attach to the firewall. Or drill 1/8-inch alignment holes. For example, this is the cowl to inner fender bracket and it is adjustable vertically and horizontally. Therefore two holes are required. The same applies to the hood hinges. Insert the drill bits to index the part and bolt it down... it is EXACTLY where it was before removal.
If you don't like random holes, the hole(s) can be hidden under the washers. I just dab and wipe a lil black RTV to seal it up. Or…………………………
Pulling the hood, scribe or sharpie the hood hinge position (all the way around) on the underside of the hood. Pulling the doors, scribe or sharpie the hinge placement on the cab, leave the hinges on the doors.
Front clip removal 101: https://www.ford-trucks.com/forums/showpost.php?p=14696880&postcount=26
Radiator bushings. D3TZ-1000155-B.. Absorber (rubber cushion) -Lowerradiator support andlowerfront & rear cab mounts / Obsolete
CARPENTERNOS OBSOLETEPARTS in Concord NC = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX = 888-727-0418.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
D3TZ-1000396-C.. Absorber (rubber cushion) -Upperradiator support andupperfront and rear cab mounts / Obsolete
PARTS INTERNATIONAL
GREEN SALES CO.
Scroll a bit to see a bushing diagram. https://www.ford-trucks.com/forums/1...l#post14696850
Also a great time to replace the steering box all together or at least the in put/ out put seals...
Old Nov 5, 2018 | 09:05 PM
Action4478's Avatar
Action4478
Yeah . Do a crap load more work for nothing .
Old Nov 7, 2018 | 11:16 AM
Aaron-71's Avatar
Aaron-71
??? If you're referring to Rich's post above yours, you couldn't be more wrong.
Aligning body panels is a giant pain, but can be avoided with a tiny bit of extra work. I side with Rich and his ideas, as they've allowed me to realign my hood in a matter of seconds instead of hours. All it took was 2 x 1/8" holes.
Old Nov 7, 2018 | 07:30 PM
NW 150's Avatar
NW 150
Okay, thanks for all the info guys! I will actually be using new fenders and a hood so I'm not worried about the alignment for those, but I'll still mark some things that will be going back in the same place. Unfortunately, looks like a bearing is bad because I have little gold flakes in the oil and the oil pressure dropped 15psi after I went 4wheeling sunday. Not sure if it's because the builder used a high volume oil pump or not, but it will be going to a different shop this time.
Old Nov 7, 2018 | 10:12 PM
GLR's Avatar
GLR
Pulled the 351M, C6 in my driveway , just took off the hood and removed the radiator.
RockWVU
Jul 5, 2012 08:33 PM
DOWN-N-DIRTY
Jul 25, 2011 09:39 AM
my774x4f250
Nov 27, 2010 05:05 AM
mrwrench
Sep 24, 2007 10:20 PM
Thudpucker
Mar 15, 2000 03:48 AM
