How to pull out Powerstroke?
Old Sep 24, 2007 | 06:20 PM
mrwrench's Avatar
mrwrench
My truck need a new engine . How to pull it out of the engine compartment .
Do I need remove the front of the truck?
can I leave the transmission on place?
thanks for advance
Old Sep 24, 2007 | 06:51 PM
beansdiesel's Avatar
beansdiesel
6 spd or auto?
Remove entire front grill and header panel and bumper. Looks daunting but quite easy accually. Remove the IC and radiator. If you are cheap like me and dont want to break the lines loose on the AC then take the ac pump and condensor loose, put a towel or fender cover over the pass. side fender then carefully take the condensor and twist it over the fender and let it hang there, the pump will have to sit on the inner fender. Just be carefull not to twist or bend teh lines, if they bend they are broke.
Now take turbo off and y pipe. From underneath pull the starter, 4 large motor mount nuts and 6 transmission bolts out (if auto take flexplate nuts off).
Make sure you have unhooked the main harness, any stray gauge wires, grounds and the two front main grounds. Two fuel lines on the driver side of the engine must come loose, you will need a quick connect tool to remove them and can be a pita.
That should be it, first timer allow about 10-14hrs to pull it. We can r&r them in about 10 hrs.
Old Sep 24, 2007 | 07:00 PM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by beansdiesel
6 spd or auto?
great tip...thanks.. 10 hr R&R is damn good...i know where im getting my turbo and inj. upgrade from...
Old Sep 24, 2007 | 07:16 PM
FN74's Avatar
FN74
Man, not sure if I am qualified to give advice on pulling the PSD or not, but I'll give it a shot. First, you do not need to lift the cab. But you do need to remove the nose. Start by draining your coolant and disconnecting both batteries, ground first. Then -Bumper(4 bolts, 17mm), grill, headlights, header panel, and A/C Evap. Remove both I/C pipes. You will notice that the cross beam that the hood latch and I/C is bolted to is removable. I believe 4 15mm bolts and 2 8mm bolts per side. Then with a little finesse, that crossbeam and I/C will come out together. Oh yeah, remove the radiator/jackhandle brackets first. Eventually, you will have a huge Hole where the front of your truck use to be.
Next remove the fan. This will take a 1-1/2" wrench, or a big crescent. Use a 10" pipe wrench on the water pump pulley to hold it while you brake loose the fan. It does come off in a normal lefty loosey fashion. Remove Intake plumbing, intake spider and turbo. Usually you want to make sure to plug the holes going to each head to prevent debris from getting in there. Remove A/C compressor and set it aside, maybe zip tying it to prevent it from slipping a little later. Undo your P/S hoses. There are 3 hoses, don't miss the one on the bottom. Buy a special fuel line removal tool so you can disconnect the fuel lines on the drivers side. On to the bottom. Remove the inspection cover on the Trans and remove the 6 T/C nuts, 13mm I think. Remove the 4 bottommost trans to engine bolts(3/4 or 19mm) then support trans with a jack. remove the two remaining top tranny bolts. This can be done from the topside as well with the turbo out of the way, but is not bad from the bottom, at least with a stock DP. While you are downthere, you will need to remove the Oil filter to clear the crossmember when coming out. The orange block heater cable simply unplugs. Remove the 4 engine mount nuts(7/8).
At this point you should be pretty well ready to go. When you hook the engine hoist up, make sure you get as tight of a pick as possible. The engine will just barely squeeze out. On initial jacking, shake the motor a bit to free it from the trans. Once you have it part way out, stop and inspect for anything still connected. There is a ground cord on the back of the passenger side head. Don't miss that!!.
Sorry for the rushed description, but I got to run off to work. Make sure you replace your up-pipes with a bellows style, replace the T/C with a good unit from John woods or PI. and Remove and inspect the flywheel if it is a manual. Good luck!!
Old Sep 24, 2007 | 07:26 PM
mrwrench's Avatar
mrwrench
great!!!!! Thanks a lot . I will start tomorrow.
Old Sep 24, 2007 | 07:30 PM
ron's power stroke
not bad for a beginner...
should put this in the mods link
Old Sep 24, 2007 | 07:36 PM
bdrummonds's Avatar
bdrummonds
Now thats funny right thar, I dont care who you are....
whover does not get the humor in that, Jason pulled his motor like 4 times in 3 days on the side of the road with a leatherman tool, 3 snow skis and a leather belt for an engine hoist, in the snow uphill both ways to and from school(oops sorry got carried away the kids are near)
Old Sep 24, 2007 | 09:34 PM
Ford79's Avatar
Ford79
http://www.dzljim.com/Ford/engine%20removal.htm
Old Sep 24, 2007 | 09:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Damn you Ford79, i had that page brought up, copied and ready to paste in a reply.
Old Sep 24, 2007 | 10:20 PM
John311t's Avatar
John311t
I can't wait to pull mine, Its gonna be a BLAST! And my oil pan is getting ran over, and anything else i can do to destroy that rusty s.o.b!
Gigemags05
Oct 11, 2014 12:04 PM
bren7176
16
Apr 20, 2014 10:18 PM
nodesy
Jan 18, 2014 11:28 AM
dyoungen
Oct 27, 2012 09:14 PM
Dannym
13
Oct 21, 2004 05:07 PM
