5.0 Starter not fitting.
Old Oct 28, 2018 | 06:51 PM
xXANBXx's Avatar
xXANBXx
Ok... first off here are the facts.
76 F100 2wd
5.0 (302): D4DE-6015-BA
3SPD: bellhousing stamped CWC behind starter
flywheel unknown but assumed correct.
Starter: Carquest 3124S
Issue: Installing starter and will not fit to save my life. Issue seems to be starter is bottoming out into the bellhousing. Double checked part numbers. Do not have an old starter that came off truck. Just purchased truck back from guy who swapped the motor. Unknown of any other changes. After researching. The CWC can only be found on 4spd bellhousing but I wouldnt see that an issue. Issue I see is inside bellhousing is a large piece blocking starter. Any help is good help at this point. Currently trying to take photos.
Piece inside bellhousing.
Starter.
Old Oct 28, 2018 | 11:44 PM
meangreen92's Avatar
meangreen92
Have you tried measuring the depth to that casting nub in the bellhousing? You could measure the starter from its mounting face to the round protrusion. In this day and age, it's very possible someone sold you the wrong part.
I do see D2AF-11131-CA cast into the starter nose, so googling those characters will shed some more information on it.
Old Oct 29, 2018 | 04:46 AM
xXANBXx's Avatar
xXANBXx
no, I have not. After fidling with it for some time I threw in the towel. I'll measure everything. I referenced the part number and it pulls back for the correct 302 though...
Old Oct 29, 2018 | 08:05 AM
DB429SCJ's Avatar
DB429SCJ
Starters are different for manual or automatic transmissions.The 3124s number is for an automatic. This should be the one you need. https://www.napaonline.com/en/p/RSE2...earchIndex=App
Old Oct 29, 2018 | 08:30 AM
xXANBXx's Avatar
xXANBXx
that would make sense, but when searching the 3124s I never see anything about automatic. I'll swing into napa and see if they have one.
Old Oct 29, 2018 | 06:38 PM
1TonBasecamp's Avatar
1TonBasecamp
When you put them side by side you will see that there is a difference in how far out the drive gear sits when in it's static position, as well as the shape/size of the snout.
Lots of issues with this two starter thing. Actually more than two were used, when you factor in the later model styles, but there were two main starters for the earlier setups.
Paul
Old Oct 29, 2018 | 06:50 PM
xXANBXx's Avatar
xXANBXx
Paul
napa will have the new one in stock tomorrow and hopefully this is an easy fix
benbuilder
Jun 19, 2017 06:40 AM
zombiehunter
Jul 9, 2012 07:08 AM
joe f350
Nov 15, 2010 10:05 AM
factory594x4
Sep 27, 2010 09:04 PM
elrod2020
Sep 12, 2007 08:24 AM
