Running boards falling off
Old Oct 28, 2018 | 05:11 PM
dmueller71's Avatar
dmueller71
Ok. I'm sure I'm not the only one at this point with rust issues causing the running boards to pretty much fall off.
what have you guys been doing to fix the issue? I have a leveling kit, and the truck sits about 5" higher than stock, and not have bad knees and getting a foot surgery, so I need the running boards at this point. Is there a reasonably easy/inexpensive fix? Are there boards or steps that mount somewhere else?
Old Oct 28, 2018 | 05:40 PM
Colorado350's Avatar
Colorado350
Are they stock or aftermarket? Do they mount to frame rail or tub? What part is rusting the truck or the mounting brackets themselves?
Old Oct 28, 2018 | 06:17 PM
Walleye Hunter's Avatar
Walleye Hunter
Yeah, some pictures would be very helpful.
Old Oct 29, 2018 | 02:11 PM
dmueller71's Avatar
dmueller71
Yes, they are the stock running boards. The mounting brackets are solid. it's the under side of the cab that's rusted through. Here's a crude sketch
Yes, it's a crude drawing. Don't have the truck with me today to take a pic
Old Oct 29, 2018 | 02:23 PM
ZachinCO's Avatar
ZachinCO
My problem is I broke the brackets from the sketch you provided. I was in the mountains hunting and took a dip to fast I didn't see. Broke the brackets. Can't find just the brackets.
Old Oct 29, 2018 | 03:03 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@ZachinCO , I might still have my OEM boards if you think that I can remove the brackets and would like me to mail them to you, hit me up via PM and maybe we can work something out.
Old Oct 29, 2018 | 03:26 PM
Colorado350
‘Zach, did you ever try the JB Weld we talked about?
Old Oct 29, 2018 | 03:41 PM
ZachinCO's Avatar
ZachinCO
Thank you Sir! I may hit you up once things slow down on my little ranch.
I gotta find my brackets still. I've got them somewhere, just have to make the time, but I am gonna give it a try.
Been busy with my little water trenching project.
Old Oct 30, 2018 | 11:04 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
If they are the factory tube running boards the brackets are aluminum. I broke at least two of mine but I also am a welder and ran a nice bead on them and never another issue ( since have replaced with power boards for ground clearance). I would never trust that part to JB Weld because I feel it will fail and it will probably be you with a bunch of stuff in your arms or an elderly friend and somebody will get hurt. I would find a welder to fix them and if you can't then mail them to me, I will do you a solid.
I also have my stock boards w/brackets that are available if someone is interested.
To the OP, again a welder will be your friend. If that was my issue I would weld a plate in there to strengthen the original mounting area and re-attach the mount.
Old Oct 31, 2018 | 09:37 PM
burnthelight88's Avatar
burnthelight88
My stock non-tube type were sagging bad on the passenger side when I bought the truck. Luckily for me it was mostly the thin metal under the board and not the truck metal. I bought after market steps used from craigslist, now of the tubular type, and they attached to basically the same points, with one extra support that ran over to the frame itself. So my point is that it seems most steps mount to the same points.
Cheapest fix is going to be cut out the rust and weld in some patch metal to secure the steps to as someone above has already suggested.
Old Nov 1, 2018 | 07:39 AM
Walleye Hunter
If it's the body that's rusted out where the nuts for the mounting bolts are located I have to wonder what the rest of the truck looks like rust wise.
reesestewww
Nov 7, 2017 10:22 PM
pooneee
2004 - 2008 F150
May 4, 2010 04:04 AM
domdel63
Mar 29, 2010 09:18 PM
dkokoshoeunit
Aftermarket Products
Jun 6, 2009 10:33 AM
72Lester
Mar 28, 2006 04:37 PM
