Right hub
Old Oct 12, 2018 | 12:51 PM
crazymut's Avatar
crazymut
Right hub
Noticed lately when driving my truck i get a noise almost like a tire rubbing on the plastic fender liners.That's not what it is. It happens when I make slight right turns, i.e. following the curve in the freeway. Noticed my right hub, if I turn the lock/free ****, the entire hub housing has slight movement in it. Maybe a 1/32 inch. Then the same going back the other way. Is this a sign of something failing? Something lose?
Old Oct 12, 2018 | 01:05 PM
DieselDenny's Avatar
DieselDenny
Time to take it apart and replace the bearing and check the axle stub for scoring. Easy job. It's the bearing closest to the truck. The outers are not replaceable. You can punch out the bearing and replace with a new seal for just a few bucks. If the axle shaft (stub) is grazed, you'll need a stub.
Either way, you won't know until it's off. Do both sides.
Denny
Old Oct 12, 2018 | 01:31 PM
crazymut's Avatar
crazymut
I was figuring something like that. Is it easier to just replace the hub?
Old Oct 12, 2018 | 02:37 PM
DieselDenny
It's easier, but if the hub stub axle is smooth, just save yourself quite a few bucks, punch out the old bearing/replace and see if it goes away.
I used to buy the hubs, not knowing the inner bearing was that easy to service. Tell you right now, I threw alot of money away.
But to echo what I said, the outer is not serviceable. You have to pull it apart, inspect and clean deep to find the issue.
Denny
Old Oct 12, 2018 | 03:07 PM
crazymut's Avatar
crazymut
Thanks Denny. Getting ready for hunting trip and this pops up.
Old Oct 12, 2018 | 03:19 PM
brian42's Avatar
brian42
Veteran: Navy
It's not really serviceable. You can pull the hub and re-grease it or pull the needle bearing and press in a new one. You won't find it on a parts list (as the hub is unitized and only sold as a complete unit) but it's a Timken B2110.
Old Oct 12, 2018 | 03:35 PM
DieselDenny
Good point. Thanx for the part Number.
If the stub survived, this would be my go to as well!
Denny
Old Oct 16, 2018 | 07:09 PM
Walleye Hunter's Avatar
Walleye Hunter
When I was tooling with mine NAPA had the bearing in stock and the guy knew exactly what it was. Mine turned out to be good so I just lubed and reassembled.
Old Oct 16, 2018 | 09:21 PM
crazymut's Avatar
crazymut
I ordered new shirt and long shaft assemblies with new u-joints and new hubs. Hubs showed up today. May remove old hubs to see if short shaft is still good and just put on the new hubs. New shafts will not make it in time for hunting trip.
Old Nov 1, 2018 | 01:33 PM
crazymut's Avatar
crazymut
Got it fixed. The needle bearings were going out. Replaced hubs, brakes and vacuum lines. Shafts were not damaged. Made my hunting trip, got skunked due to passing on average deer. Stopped for diesel in one town and had this guy come up and ask me, You’re selling your truck aren’t you? Because it’s sold now. I’ll buy it right now. I didn’t sell it. 211k on it, nearly 2000 mile round trip, it ran perfect. 15 hours each way. I don’t know if I could sell it.
RigCity
Aug 8, 2017 10:35 AM
Shattered
Nov 23, 2015 12:59 AM
SpeedRebel09
Apr 19, 2011 05:36 PM
zavierbr
Dec 23, 2008 08:39 PM
RACERX7775
Sep 27, 2006 09:41 PM
