Was there an ignition control module?
Old Nov 14, 2018 | 07:17 AM
  #61
KULTULZ's Avatar
KULTULZ
Post
Originally Posted by turpentyne
He had the old '58 distributor in there, and it worked, but the afore-mentioned timing light showed things moving about a little, and he said that the plates in the distributor were maybe a little looser than they should be (or the shaft - it is a 60-year-old distributor.
A note on that 57-59 early style DUAL ADVANCE DIST. The upper plate rides on ball bearings instead of having the plates hinged on a pivot bushing (59/ ). Those ***** get gummed up/out of round. If you take the plate off and clean your ***** ... sheesh ... it should start to function correctly. Bad bushings/breaker plates lead to dwell variance and spark scatter which is probably what you are seeing with the timing light.
Also, quality POINTS-CONDENSOR which are still available from MOTORCRAFT.
One Sock
Apr 11, 2019 05:50 AM
mdbbrown
13
May 13, 2017 08:03 PM
ptalbert33
Aug 4, 2010 06:35 PM
padlikehel
Mar 19, 2010 07:57 AM
Biscuits
Oct 5, 2009 06:21 PM
