Was there an ignition control module?
https://www.ebay.com/itm/392161370859?ViewItem=&vxp=mtr&item=392161370859
After NumberDummy cleared that one up, I went over to Summit Racing and got the correct part, and some points.
Once they arrive, we'll see if that resolves things. I think he's going to clean the points today. They're new, and we're in a dry environment (Arizona), but we did get a few freak rainstorms over the last month.
Thoughts? Concerns?
As for his idea of putting the wire directly to the plug? Seems legit to me. Never tried it, but it certainly eliminates extra layers and you can then decide whether it's likely to be the coil, the wire(s), or the plug(s).
Might be extra work, but nothing wrong with the theory that I can see.
Paul
Thoughts? Concerns?
As an experiment, he opened up the point dwell a little, and it did help. But still not starting.
I think I'm going to order some wires just to eliminate those as a contributing factor, if I can figure out where. (at the moment, easier than making them) Other than battery cables, that's about the only thing that isn't new.
That'd be the little coil-to-distributor wire, the longer ignition switch-to-coil wire... I think... (#16 in diagram) ...any others? Not sure of part numbers.
I'm a little confused on which/where the resistance wire is on this. If there is one? Ignition switch to firewall?
Another thing I want to check - I think @1TonBasecamp alluded to it. I wanna check the coil resistance and maybe the resistor wire. I was just reading that new coils might be lower resistance, so the wire could be cutting power too low and maybe that's why the weak spark. Maybe his opening of the points improved things because it's trying to overcome the real underlying issue.
Does anyone know what the resistance should read at the coil? I'm assuming the '70 has something like the pink resistor wire in the dash somewhere?
Here's the situation to date: We've solved the starting problem, but -- as with any good answer -- we ended up with even more questions. Yay.
Here's what happened: Yesterday, we tested every single coil and condenser we had (3-4 of them each). Not the issue. They all tested just fine with the meter. In fact every single component of the ignition system in that sense, is just fine. After I threw on (yet another) brand new condenser, I hopped in and tried starting. It sounded like it wanted to. I asked my dad about that, and he said "Yeah. That's what it was always doing. It'd try a few times, then did this the rest of the day"
"Well throw some gas in the carb and let's try again, " I suggested.
We did, and it made a noise. Not sure what happened at this point... either he bumped the distributor, or just started turning it on a whim, but he saw an improvement. So he kept twisting and I kept turning her over. The truck started. By this time, the distributor was turned enough it appeared that everything was pointing one cylinder off. But that didn't seem right.
Just to see, I went ahead and shuffled all distributor plugs one clockwise. The truck fired up. But everything looks..."off." First of all, the vacuum advance was pointing off to the driver's side corner of the fender. I'm pretty sure it should be pointing straight forward if things are dialed in correctly. When he was twisting it earlier, the vac advance was pointing as far as it could go to the left.
At that point, we stopped for the day. We went for coffee and wondered if somehow the shop that rebuilt things put the distributor in a tooth off. or maybe it didn't seat into the oil pump correctly - then dropped into place and threw stuff out of timing. But it all seemed weird, because the truck was running for a couple hundred miles of driving before it fouled on him, going home one day, and then this "can't even start it" issue began. He said the oil pump's been working right the whole time. But wait...there's more...
This morning, he texted me that he was out fiddling with the truck, and it's... "Still not right. Going over 1000 rpm, loses power to tach and fouls real bad (but doesn't stall). Disconnect the vacuum advance and it's fine. No fouling. Looks like something going on with vacuum advance. I'm thinking too much vacuum at carburetor" He's put the plugs back to where they were yesterday, and moved the distributor back to re-create the situation where the vacuum advance points forward but the truck doesn't start, unless he turns the distributor a full inch or more clockwise. EDIT: Basically, at this time, the problem is: he can start the truck and it'll drive with the vacuum advance disconnected. the plugs and timing are all good. The vacuum advance is pointing forward. The carb is rebuilt. ...but, If he attaches the vacuum advance up, the truck runs rough and doesn't accelerate. It'll run ragged and try stalling if he accelerates normally. He can overcome it by "stabbing the pedal like a race car driver" but that's no good.
Personally, I still feel like the distributor needs to be moved a tooth, and everything readjusted? I dunno. I'm stumped. I'm hoping someone has thoughts on what to check? At least it's not the electrical stuff anymore.
Next, are you using a timing light in all this? Doesn't sound like it, and it's not an absolute requirement. But it sure would definitely be nice to have now that you're twisting the distributor and knocking about with different aspects of timing.
Now, a tachometer, eh? Tell your dad to disconnect it from the coil completely and try again. Old tachs can kill an ignition with an internal fault and cause all sorts of hair-pulling sessions. So for testing purposes, you need to have only two wires to the coil. The Black wire from the distributor to the negative side, and the Red w/green wire to the positive side. Nothing else, not even the radio noise suppressor if it's still there. Just the control wires. Power and ground.
And while you're doing all this, closely inspect the harmonic damper on the crank. Look for any telltales that appear to be matching notches in the inner and outer rings. When new they are perfectly aligned. If the rubber isolator deteriorates sufficiently the outer ring can spin on the inner, putting your timing marks off and giving mixed signals.
Obviously this is not a big issue if you're not using a timing light in the first place, but if you do start to use one you will need to know this.
It does not really matter to timing where your vacuum canister is pointed, or where number one plug wire is on the cap. As long as everything is aligned to the correct plug when the piston is where it's supposed to be, your engine will run. However, as you noted the location of the canister is almost always within a certain range because otherwise it can run into physical obstacles that keep you from advancing or retarding your ignition timing properly. And the number one plug wire should always be on the same point on the cap because that's what Ford set up for consistency. All the caps used to even have a #1 embossed in the cap, but I'm seen a lot of them that don't have that anymore. Not sure if yours does or not, but if it does you should continue to use it.
Re-re-verify the correct firing order for your engine. And I don't remember seeing mention of what engine we're talking about here? What is it? V8? Six? What size?
Paul
He's replied back that he did disconnect the tach and got the same thing. There's no other wires connected, I don't believe.
We haven't been using a timing light. We just used the "Stick a screwdriver in spark plug hole 1, and make your son crawl underneath to turn the damper pulley" method.
EDIT: To clarify, he can start the truck now. It's turned into to a "won't run right if vacuum advance is connected" issue, it seems
But, currently the 'no-start' situation has turned into "It starts, but won't run right with vacuum advance attached".
The distributor symptoms you describe just means it was simply stabbed wrong. It doesn't particularly matter so long as the full range of housing movement is available, otherwise it might hit something before it can be timed correctly.
All the timing settings and checks are first done with vacuum advance canister disconnected and vacuum port plugged.
Make sure the internal distributor advance mechanism is working OK by observing that the timing light & marks move up and down the damper smoothly over the RPM band and the marks don't stick, wander, or scatter when observing with a timing light. Make sure it's done advancing all the way. Take a test drive without vacuum advance connected. Check for ping or engine knock on hard acceleration &c. Keep advancing in slight increments till it is running good. Then don't **** with it again.
Check to see that the vacuum advance canister diaphragm holds vacuum, otherwise it will present a big leak and carburetor runs lean, plus no extra ignition advance when needed. If it checks out OK, then it probably just need to be tuned. Remember though, you're already done at this point with the distributor tuning. Don't adjust the distributor ignition timing to compensate for a misadjusted vacuum advance. What Crane suggests for their vacuum canisters is to start with the can at maximum canister advance (fully clockwise) and test drive. Back off 2 full turns with the allen wrench if part throttle rattle. Test again. Rinse lather repeat.
Vacuum advance adds more timing on top of the distributor mechanical advance timing but only when engine load is very light, especially as when cruising on level ground in high gear. It pulls it back out when ever a heavy load is present and back in as load levels off. It is constantly pulling in and releasing small amounts of advance (through the breaker plate) during normal stop and go driving too. It gets a workout.
So make sure breaker plate moves smoothly back and forth and releases and is not sticking when vacuum is applied and released to the canister. Vacuum advance allows for cooler engine temperatures and better all around driveability on the street plus adds maybe 3 or 4 mpg to a V8 when tuned correctly. Unless you're drag racing Always use vacuum advance!
