Ultimate lariat folding mirror replacement
Old Oct 23, 2018 | 01:10 PM
PD Rig's Avatar
PD Rig
gentlemen,
A friend of mine has damaged his mirror on his '19 f350 lariat. This mirror has all the bells and whistles. Lane assist, camera etc. He got a new mirror and plugged it in. Now he has a short to battery/open code and 2 other codes. I tried to clear to codes, but they came back. We plug the old mirror back in and codes go away.
Any of you guys replace a mirror with cameras/lane assist and have to do programming. It's either that or the new mirror (supplied by stealership) wiring is no good.
Thanks in advance.
Dan
Old Oct 23, 2018 | 02:17 PM
seville009's Avatar
seville009
If you haven’t already done so, check to make sure the wiring in the new mirror isn’t damaged somewhere and shorting out. Just a guess.....
Old Oct 24, 2018 | 07:10 AM
GABAR's Avatar
GABAR
Originally Posted by PD Rig
gentlemen,
Thanks in advance.
Dan
Well, if the codes go away when the damaged mirror is reinstalled, you "might" have just solved the mystery.
The "new" mirror is defective or some kind of BCM programming is required via the Ford dealer.
However, I would install the damaged mirror and make sure the codes that you saw will not come up after awhile but then again, maybe something was damaged in the mirror that would not cause the codes to show up.
Let us know if you`re able to get the mirror working properly on your truck.
Old Oct 24, 2018 | 08:22 AM
FastTaurusSHO's Avatar
FastTaurusSHO
Considering the backup cameras require some programing when replaced, it wouldn't surprise me the Mirrors require the same.
Old Nov 7, 2018 | 01:28 PM
PD Rig's Avatar
PD Rig
Back around to post the results. So it turns out that the wiring on the new mirror was no good. The dealer i bought the new mirror from held warrantying the bad new mirror until the could check the truck for themselves. Being in the electrical industry for a number of years it is not that uncommon one to get duds from the factory. New mirror. Problem solved. There is no programming required. All the devices in the mirrors are pin to pin connected to the door control module.
Thanks,
Dan
DingBat
2009 - 2014 F150
Sep 14, 2009 06:52 PM
Spaggs
Sep 4, 2008 02:02 AM
palindromelol
Aug 23, 2005 01:23 PM
Janet
1997 - 2003 F150
Nov 21, 2003 11:43 AM
