Never seen that before,
looks like it’s their own kit but the turbo provided is a 58mm which is rather small and a .83ar exhaust side.
Also rather expensive for what they give you, I’m surprised there are more kits out there that aren’t advertised at all.
I didn't look past that it was another T4 mount...maybe you could purchase everything but the turbo and source that yourself.
The CSD Mont has the turbo exhaust flange more parallel to the ground, correct?
I think the would be enough room in front of the turbo for the Y pipe without the got side. The slant in the mount would seem to make installation a little easier by providing some vertical clearance. Or am I seeing that wrong?
Ah, I went and looked more closely at the CSD mount and see what you mean. I also like that the CSD mount has the uppipes welded to it, one less connection to hassle with. The product pictures on their website of those welds look kind of rough. I hope the product you received is neater.
If you look closely at the CSD welds on the collector, you'll see that they have to put a bunch of filler in the area where the two uppies come together. I forget what the inside of the collector looks like exactly, but do recall it was ground and shaped.
