Problem is whatever you do to the exhaust you will have to undo to pass your state inspection. Unless they don't inspect emmissions. if you replace only the DPF and install a tuner then the reversal will take only an hour or so. once you've done it it's pretty easy. If you start taking other parts of the exhaust off then you make it much harder. I am not deleted but was with my 6.4 and this truck doesn't look much different. Trust me, if you get the DPF out of the way you will have all the power and noise you want.
^^What Stanley said. It's a pretty straight forward process. The equipment on the 6.7 is a little heavier than the 6.4s were so if you end up doing it yourself, just keep that in mind so it doesn't pin you to the driveway.
Good information as usual folks, I towed about 200,000 miles and now am off the road with a regular job. It will be nice to have the gains in mileage for my daily commute. I don't need a ton of power but I don't like the egr contaminating the oil however. My 7.3 is another story
Outlawed seems to be the way to go but I don't want any trouble either
Just do it! You will LOVE IT!. Just keep everything and block off and unplug the EGR. That way you only have to put two connector flex pipes, and the DPF on when it's inspection time. I BET. You could even go to one of those cool "Economic" pay places. 15-20 more, but I bet they don't look.
Darn UGA at my age the one off the 6.4L almost pinned me. I still have that thing in my shop attic. i figure one day somebody will need it and I can get some of my money back. GO DAWGS.
Got access to a military base? Go to their DIY shop....you'll need a lift capable of supporting over 10k#, and a transmission jack. Cost me $40 for the time and the jack....almost 5 hrs.
I'm confused about the tranny jack, oh I get it you use the jack to hold the DPF while loosening it. Yeah, that sounds OK. Did mine ( 6.4) by driving up on the blocks I use to change oil. Lay
id on my back and it came off pretty easy. if you have a strong helpful wife ot girl friend you don't need the jack. Don't tell mine I said that though.
I laid a piece of plywood under the truck (on top of my rock shop approach ramp), and used a floor jack to hold up the dpf.
I did it on a vehicle lift at the DIY shop on Ft. Huachuca... getting the DPF off wasn't bad because I asked for help, so me and 2 other guys held on to it while I unbolted the hangers from the frame then we took it off. I used the tranny jack to help keep the pipes up so I could align them before clamping everything down.
