Top Loader 303 ID Help
Old Oct 22, 2018 | 02:54 PM
RattyFord's Avatar
RattyFord
I picked up a toploader 3 speed for a bargain price the other day. It was bolted to a 351... best I could tell by the valve covers and exhaust manifolds. The casting on it is D2AR 7006 AB and the tag is RAN CU over JC ##0995 (#= unknown number).
Any help appreciated. I've found lots of toploader charts but none of them have the AB from the casting, or the CU from the tag.
Old Oct 22, 2018 | 07:02 PM
85e150's Avatar
85e150
Found this one, looks like it might could be the same as yours, although that casting revision date of "D2AR" is a 1972 version, so it could have appeared in other or earlier models as well.
https://secure.cougarpartscatalog.com/ran-cu.html
Old Oct 23, 2018 | 09:37 AM
RattyFord's Avatar
RattyFord
That's definitely it... even has the AB, but you're right about the D2 for 72.
Old Oct 23, 2018 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The casting on it is D2AR 7006 AB and the tag is RAN-CU
RAN-CU = 1974 P (Maverick/Comet) 302 w/a floor shift (see application in pic below).
Old Oct 23, 2018 | 02:11 PM
RattyFord's Avatar
RattyFord
That's really weird because that's what the tag says, but the casting is clearly D2AR 7006 AB
Old Oct 23, 2018 | 02:23 PM
NumberDummy
That's really weird because that's what the tag says, but the casting is clearly D2AR 7006 AB :
D2AR-7006-AB is the casting number for the transmission case only, it is not the identification number for the trans. The trans ID number is RAN-CU
The case was used in myriad 1972/78 cars with RAN trannies.
Old Oct 23, 2018 | 03:25 PM
RattyFord's Avatar
RattyFord
Ahhh!!! Thanks for the clarification.
cpscholz
Jul 5, 2019 09:26 PM
scottlathrop
Oct 28, 2014 07:15 PM
C-700
Large Truck
Dec 12, 2010 04:29 AM
cruisinright
Dec 31, 2007 07:41 PM
zzcharger
Jan 20, 2003 10:53 PM
