Lifting points
Old Oct 21, 2018 | 10:35 PM
john jamieson's Avatar
john jamieson
Lifting points
I have a '93 300 sitting in a small trailer. I see it has a lifting ring at the front. What is the best place to attach a chain at the rear for lifting?
It still has the bell housing attached.
Thanks.
john
Old Oct 22, 2018 | 07:12 AM
arse_sidewards's Avatar
arse_sidewards
There's an unused bolt hole on the block in the vicinity of the temperature sender for the gauge. I bolt a cheap slip hook (like the kind that comes on the ends of those $10 tow straps you can buy at Walmart) on there.
Old Oct 22, 2018 | 06:47 PM
AbandonedBronco's Avatar
AbandonedBronco
If the manifolds are removed, you can always put a bolt into the head where the manifolds bolt up.
superduty4x4
32
Apr 1, 2008 08:08 PM
scottie2hottie
Garage & Workshop
19
Jun 5, 2007 12:07 AM
kingcavinee
Sep 28, 2004 07:57 PM
tallibasher
Nov 15, 2003 04:48 PM
pcmenten
May 20, 2002 07:32 AM
