Stuck bolt in rear yoke revisited
Tried to get it out again today- drilling for an easy-out is a no-go (not enough room without a right angle drill) so I did the straight slot with a Dremel trick. Squirted some penetrating oil on it and let it sit for a while. Came back out with a 1/4" ratchet and a screwdriver bit- still no go. I actually bent the tip of the screwdriver bit trying (couldn't get a conventional screwdriver in there very good- again not much room to work).
So, now what? I don't want to cut the bolt head off for fear of not having anything to grab with vice-grips. Although if I do, I could probably drill and easy-out what's left behind with the driveshaft out of the way. Anyone else have a bright idea?
on
I have had problems with many of those bolts in my years. Biggest problem is worn sockets that don't get on the head straight which then strips the head out. I use a cut off wheel and cut the head of the bolt off. then use vise grips on the stub. Never had that method fail me once. I live in Michigan so rust is a major factor as well. But you won't have to worry about rust. Once the head is off the bolt the tension is relieved and it might even come out with your fingers.
Originally Posted by F350-6
Do you have any needle bearings laying around? If you look at a picture of the gator socket, maybe you could duplicate the concept with the closed end of a wrench?
The Irwin extractors appear to be shallow sockets. Would those work?
How good are you with a dremel? Could you cut 2 flat sides on the rounded bolt opposite of each other that a wrench would fit on?
Tim- are you able to cut the bolt head off flush with the strap, then still have enough to grab with vice grips? My thought was to round out the head/shoulder on the head and slide the strap off so I don't sell myself short on real estate to grab with the vice grips.
Chase,
Here's a wild suggestion. You want to replace the carrier bearing as well as grease the spline, right. Remove the front section of the drive shaft at the x-fer case. Then slip it out of the carrier bearing. Unbolt the carrier bearing and then you can slip the back section of drive shaft off at the spline.
Originally Posted by PaysonPSD
Chase,
Originally Posted by tjbeggs
You can buy a bolt and strap kit at Napa for a few bucks. Your gonna need it anyway since you need a bolt. Cut which ever part you want. the bolt or the strap. Trust me I have done this more times than I care to count and never had a problem. (famous last words....)
