Sync problems
Old Oct 21, 2018 | 07:59 PM
greenheads's Avatar
greenheads
Sync problems
i have a 2017 f150 xlt using iPhone 6s using latest update. I think my sync is version 3.0. I started having problems with the last few weeks. With or with out my phone connected via Bluetooth the touch screen has gotten very slow to react. If I touch the navigation icon it could be normal speed to move or up to 8-10 seconds to go to the screen.
if I hit the voice button on the steering wheel I get the same issue. As she is talking she will freeze mid sentence for 4-5 seconds then continue.
also my navigation after driving a little while will have a white circle with an X over the word GPS and it is not tracking me correctly. I do not have a lift and am running factory tires.
However if I plug my phone in and use apple car play everything works as normal for now.
I have tried master resets a couple times and have disconnected the battery. Any tips or tricks on this? Thanks for the help
Old Oct 22, 2018 | 07:14 AM
GABAR's Avatar
GABAR
Sounds like your APIM is going bad and a Master Reset or battery disconnect will not solve your problems.
This is a known problem and it`s only going to get worse. The APIM is basically the brain of the SYNC 3 system and it`s attached to the back of the display screen.
Take it into your dealership to confirm because more than likely they`ll have to order a new one. I hope you`re still under the factory mileage warranty otherwise, get ready to hand over 1K to the dealer for a replacement APIM.
Have a good day.
Old Oct 22, 2018 | 08:57 AM
greenheads's Avatar
greenheads
Have a good day.
Thank you for your help, unfortunately my 17 month old truck already has 63,000 miles on it so this is on me. I looked up the APIM part number and it looks like it is HP5Z-14G371-J. I found it for $516 at spikes ford parts online. is this something I can change myself or does it have to be programed at the dealer?
Old Oct 22, 2018 | 03:00 PM
biz4two's Avatar
biz4two
Arrow
So, what version of 3.0 do you have?? Need to verify your version at head-unit...and logon to FORD site (register if you haven't) and see if you have an update available.
https://owner.ford.com/support/how-t...c-updates.html
https://owner.ford.com/support/how-t...date-sync.html
Good luck...
biz
Old Oct 22, 2018 | 03:13 PM
greenheads's Avatar
greenheads
Here is a picture of software version, appears version 3.0
Old Oct 22, 2018 | 03:31 PM
biz4two's Avatar
biz4two
Arrow
Sorry, but no picture. However, have you registered with the site? Using your VIN the site will let you know if you have an update available. If yes, then try updating first.
Also, it is extremely important to "CONFIRM" the update was successful. You will receive an email asking you to confirm...
biz
Old Oct 22, 2018 | 03:38 PM
greenheads's Avatar
greenheads
biz
I just followed your link and it says up to date, last confirmed install of an update to your vehicle was on October 10, 2018. this is about when it started having problems. is there any way to go back to a previous version or once its screwed up its done?
Old Oct 22, 2018 | 03:44 PM
biz4two's Avatar
biz4two
Arrow
Ahhh, that is not good to hear. My hope was that an Update would cure the issues. Unfortunately, I am not sure if you can roll back an update?? That is probably on a question a dealer could answer...as in a Master Reset to like when NEW and took delivery.
biz
Old Oct 22, 2018 | 03:55 PM
greenheads's Avatar
greenheads
So would a new APIM have to be programmed by the dealer or is it just plug in a new one and its ready to go?
Old Oct 23, 2018 | 07:48 AM
GABAR's Avatar
GABAR
Yes, you can change it yourself but it will have to be programmed because they are vehicle specific and some of the vehicle info such as the VIN has to be programmed into it and so far, the only way this can be done is via a Ford dealer.
Old Oct 23, 2018 | 07:52 AM
GABAR's Avatar
GABAR
Yes, it`ll have to be programmed by a Ford dealer and unless something has drastically changed.....meaning recently, this is not a simple plug in the new part and you`re ready to go.
Old Oct 23, 2018 | 07:54 AM
greenheads's Avatar
greenheads
thank you you for the help. Is this programming done through the obdii port or the USB port. Or is it done directly on the apim. The reason I ask is when does it need to be programmed. Before install. Before installing the dash or after finishing install.
Old Oct 23, 2018 | 08:21 AM
GABAR's Avatar
GABAR
If it`s anything like MFT, the programming is done via the USB ports after the install.
Since this is SYNC3, it might be different so i`m not sure if anything has to be done to the new APIM before or afterwards.
There`s a video on YouTube showing the procedure for programing an APIM from a Ford tech on a MFT equipped vehicle. The video is 6:42 minutes long but it does include time lapse of the procedure. This will give you an idea of what the dealer has to do. If you`d like to watch it, just type in Ford APIM programming.
Old Oct 23, 2018 | 12:41 PM
biz4two's Avatar
biz4two
Arrow
Hope this video helps...answer some questions.
biz
Mack3006
Jun 7, 2019 07:12 PM
JustinSouthTex
Dec 19, 2018 09:01 AM
1504ever
2015 - 2020 F150
Feb 24, 2018 03:16 PM
TravT
Dec 23, 2017 08:54 AM
RFarrow
May 1, 2013 11:57 PM
