Question about rust
Question about rust
I have a 76 F-150 from Arizona with almost no rust. I current live in the northern Illinois area, close the Wisconsin border.
I don't have the money to get rust proofing done currently.
I plan on getting the rust proofing done next year so it would only be exposed to the salt on the roads for one winter.
I was wondering if the truck would get really rusty from driving around this winter.
I don't want to ruin the truck as the body and frame are in really good condition
Agree W/fordguy2100. Try to get a winter beater vehicle, keep in mind Ford isn't making anymore 1973-79 generation Trucks. I grew up in the rust belt and remember delivering newspapers (1968 1971) and seeing a vehicle in three years that you could put your fist through the lower quarter panels, especially rocker panels. More than likely you'll regret not stowing 76 Ford P-U truck for the winter.
If you need something cheap you can use Linseed Oil. There are boiled or raw oil. I have used boiled. I used it thinned in a cheap Spray Gun. ( the gun was set with low air prussere and high paint flow)
Be careful not get the oil on Brakes or Exhaust and be VERY CAREFUL if you get Linseed Oil on
flamable material such as a rags of cloth because it could ignite when producing heat.
Otherwise it's pretty harmless and if it's thinned right it would not dissolve old undercoating.
Once salt hits the truck it's done. You can't go back and from here on out you will have salt creeping in seams, welds and crevices. Why would you subject a rust free vehicle to the winter roads anyway? If you must then get yourself a Hudson sprayer and use a 75/25 mix of used engine oil and diesel fuel and really get in the seams.
flowney
26
03-04-2019 03:00 AM
