Question about rust
Old Oct 9, 2018 | 10:03 AM
AmericasFinest's Avatar
AmericasFinest
Question about rust
I have a 76 F-150 from Arizona with almost no rust. I current live in the northern Illinois area, close the Wisconsin border.
I don't have the money to get rust proofing done currently.
I plan on getting the rust proofing done next year so it would only be exposed to the salt on the roads for one winter.
I was wondering if the truck would get really rusty from driving around this winter.
I don't want to ruin the truck as the body and frame are in really good condition
Old Oct 9, 2018 | 10:07 AM
HIO Silver's Avatar
HIO Silver
No money to do it right now? Get a pump sprayer (or multiple large cans of WD-40) and periodically douse the entire undercarriage with a light oil.
Old Oct 9, 2018 | 01:31 PM
jackietreehorn's Avatar
jackietreehorn
I am curious, what does it cost to get rust proofing done, $150? Do you mean a spray with oil/wax or like painting with liner?
For the first option I think its money well spent considering the thousands rust repair costs.
Old Oct 9, 2018 | 01:35 PM
fordguy2100's Avatar
fordguy2100
If you're worried about rust and can't afford to rust proof it, sounds like you can't afford to drive it in the winter. You'll spend way more in rust repair than rust prevention. Don't risk destroying a great truck.
Old Oct 9, 2018 | 03:22 PM
EQCMCAT's Avatar
EQCMCAT
Agree W/fordguy2100. Try to get a winter beater vehicle, keep in mind Ford isn't making anymore 1973-79 generation Trucks. I grew up in the rust belt and remember delivering newspapers (1968 1971) and seeing a vehicle in three years that you could put your fist through the lower quarter panels, especially rocker panels. More than likely you'll regret not stowing 76 Ford P-U truck for the winter.
Old Oct 9, 2018 | 03:27 PM
Matt1966's Avatar
Matt1966
If you need something cheap you can use Linseed Oil. There are boiled or raw oil. I have used boiled. I used it thinned in a cheap Spray Gun. ( the gun was set with low air prussere and high paint flow)
Be careful not get the oil on Brakes or Exhaust and be VERY CAREFUL if you get Linseed Oil on
flamable material such as a rags of cloth because it could ignite when producing heat.
Otherwise it's pretty harmless and if it's thinned right it would not dissolve old undercoating.
Old Oct 9, 2018 | 03:43 PM
ford390gashog's Avatar
ford390gashog
Once salt hits the truck it's done. You can't go back and from here on out you will have salt creeping in seams, welds and crevices. Why would you subject a rust free vehicle to the winter roads anyway? If you must then get yourself a Hudson sprayer and use a 75/25 mix of used engine oil and diesel fuel and really get in the seams.
Old Oct 10, 2018 | 07:48 AM
AmericasFinest
I took it in for a quote at LINE-X and they wanted like $400.
They spray this nasty tar crap all over everything.
I have seen videos where people have gotten that tar crap
sprayed under there truck and it actually makes it rust out faster
because it locks in moisture.
Old Oct 10, 2018 | 07:52 AM
AmericasFinest
I'm just gonna let it sit in the driveway over the winter.
It would be a shame to ruin this truck.
Old Oct 10, 2018 | 09:31 PM
78Broncoinpieces's Avatar
78Broncoinpieces
in northern Ohio it cost me $150 to get Fluid Film sprayed on. its a thick waxy oil. there are other similar brands. that type of product creeps into the seams after application.
for a rust -free truck, best bet it to keep it off the roads in winter.
Old Oct 11, 2018 | 07:30 AM
Ozzie H.'s Avatar
Ozzie H.
I agree. A garage would be even better. If you must drive, use some rust bucket that's shot anyway.
flowney
26
Mar 4, 2019 03:00 AM
Greywolf
Projects
Jul 10, 2012 12:32 PM
fordman2267
Paint & Bodywork
Apr 23, 2008 03:49 PM
biggreen78
Paint & Bodywork
Oct 25, 2004 01:17 AM
Powerstroke baby
Paint & Bodywork
Sep 28, 2003 03:46 PM
