C6 1977 ATF
Old Oct 10, 2018 | 11:23 AM
Matt1966's Avatar
Matt1966
C6 1977 ATF
My C6 -77 Dipstick shows ESP-M2C138-CJ. What kind of ATFshould I use? Dexron II ?
Thanks!
Old Oct 10, 2018 | 12:19 PM
Dave145's Avatar
Dave145
You may wish to try searching for this via the search bar at the top of the forum. It's been beat to death a million times.
Old Oct 10, 2018 | 02:15 PM
Matt1966's Avatar
Matt1966
I tried but it was almost impossible for me to analyse all answers. I found a lot of different opinions, even answers
like " I have always used Type F in all my aut transmissions without any problems".
That's why I would appreciate some direct answers here. Thanks!
Old Oct 10, 2018 | 03:52 PM
HoustonDave's Avatar
HoustonDave
In general, I would suggest that if you see someone contradicting all the rest of the answers with "I've done that for years, no problems" - who are you going to believe, Ford engineers or someone you know nothing about? Me, I figure using stuff compatible with factory specs has kept my truck alive 40 years. Use the Dexron. I think anything compatible with Dexron III is compatible with II. But, I'm just another anonymous guy on the internet!
Old Oct 10, 2018 | 05:40 PM
DB429SCJ's Avatar
DB429SCJ
M2C33-F = F TYPE; M2C138CJ = Dex/Merc
Old Oct 10, 2018 | 08:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4 & C6 used type F thru 1976, Mercon from 1977.
Old Oct 11, 2018 | 11:18 AM
beartracks's Avatar
beartracks
Type "F" will typically give you firmer shift. "I've used it for years" in C6 trannys and power steering systems
Old Oct 11, 2018 | 11:25 AM
ford390gashog's Avatar
ford390gashog
Being that the C6 was never upgraded with better clutches Type F is generally the better fluid. FYI Mercon was phased out a long time ago so don't accidentally put the wrong fluid in. Most bottles say not for use in applications requiring Type F and this warning extends to the C6 also. You can still readily get Type F.
Old Oct 11, 2018 | 05:00 PM
Matt1966's Avatar
Matt1966
This time I dont know what to say??
So I can use almost whatever I want?
Old Oct 11, 2018 | 05:02 PM
dlburch's Avatar
dlburch
now you have your very own answers to analyze!
Old Oct 11, 2018 | 05:19 PM
Matt1966's Avatar
Matt1966
Yeeeeh!
Thanks anyway!!! Maybe I will start a new thread about Engine Oil???
Old Oct 11, 2018 | 05:52 PM
ford390gashog
Nope, you want a low to zero friction modified fluid. I suggest type F.
For-dragon
Apr 27, 2014 08:33 PM
tbenks
Jan 22, 2010 10:54 PM
crescentwrencher
39
Apr 13, 2008 09:46 AM
ProjectsCa
Jul 22, 2006 10:59 PM
turbopop
Feb 26, 2005 03:00 PM
