Water pump
Old Oct 9, 2018 | 05:40 PM
Roc2525's Avatar
Roc2525
Water pump
I'm changing the water pump on my 02 250 7.3 what else so I replace Besides the water pump and what kinda of coolant so I use the water I bought is sorted aw4114
Old Oct 9, 2018 | 05:55 PM
Colorado350's Avatar
Colorado350
Welcome to FTE! Probably want to proofread and punctuate, it makes figuring out what you’re trying to ask a lot easier. I’d replace all the hoses, do an extreme flush and being an 02 you should be able to use ELC.
Old Oct 9, 2018 | 08:31 PM
roostercrows's Avatar
roostercrows
What he said ^^^. Also go with the Navistar water pump with built in filter from Diesel Site.
There is a procedure here: https://www.ford-trucks.com/forums/9...ighlight=gooch it tells you how to properly flush your system and what the best coolants to use are.
Old Oct 9, 2018 | 08:45 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I recently did my pump at 200k but wanted the coolant system the same age so I dont have failures as various parts age. ford recommends you change the fan clutch when you replace the pump. I did a pump,thermostat, thermostat housing, fan clutch, radiator, tensioner, idler pulley, all 5 coolant hoses, ECT sensor and flush then added ELC for coolant. Entire coolant system should be good for another 200k of worry free service.
be sure to use the motorcraft thermostat and o ring gasket. The stant style gasket is leak prone in a motorcraft or navistar pump housing.
Old Oct 9, 2018 | 08:58 PM
timmyboy76's Avatar
timmyboy76
Run the Airtex you purchased. Mightcwant to run a new oem tstat and billet housing...welcome to the non IH pump side...
6ohman2004
Dec 26, 2024 12:49 AM
'74 Ford 250 CS
25
Oct 1, 2018 01:25 PM
BIGRED 7.3L
Jan 5, 2013 12:39 PM
pminne
Nov 30, 2007 09:54 AM
Larry Heath
Nov 2, 2003 07:31 PM
