99 ford f250 7.3 zf6
Occasionally I will have to roll forward or backward (a few inches to 1 foot or so, not much) to get the truck into low or reverse and rarely 1st, but it does happen. This has been my experience with any manual transmission I have driven in any vehicle though.
How long have you had the truck?
Did the previous owner say if he saw or was told the condition of the clutch fork?
What sort of clutch did he put in it?
Was the flywheel replaced or resurfaced?
Did the transmission make this noise when you bought the truck? Did the previous owner mention anything about it, even if it was BS?
I would ask about the fluid as well to see if he remembers or cared to remember?
If you are still unsure, you could do a fluid change to a quality fluid (I have used Amsoil ATF, Redline MTF and now on Redline High Temp ATF which I really like) to be sure that is not the problem. Check the easy things first, then go on to the surgery if required.
Need more information here before we can offer advice. If you can get a video of the sound, that would be even better.
We would like to help, but having all of the pieces to the puzzle helps to solve it...
It did not make the noise when I first got it that I can remeber, have had it since Feb, i have never had to let it roll forward before to get it into gear, and I asked what kind of oil and he said tbe valvoline high milage for transmission (he maybe blowing smoke) he does not remeber amything else since it has been so long. I will work on getting a video of the noise but it is the same noise that it make say if you goto downshift into a lower gear and it's not ready to go into that gear
