Question on DPF cleaning.
Old Oct 8, 2018 | 04:18 PM
mck2000's Avatar
mck2000
I have dpf gauge up on the dash. Yesterday was driving gauge showed filter full drive to clean. Was stuck in race traffic for awhile. Once on the highway gauge started to drop and bottom out at 35% than started to rise. My trip home was about 150 miles or so. Does this sound right. Contacted dealer service advisor said it was. 2016 F250 driving empty. Thanks in advance.
Old Oct 8, 2018 | 05:43 PM
Just Strokin's Avatar
Just Strokin
That is not uncommon for the percentage to not drop as low as it normally does. My truck did a regen today and stopped at 30% when it normally drops to 15%-25%
Old Oct 8, 2018 | 06:11 PM
mck2000's Avatar
mck2000
Ok thank you. There are so many different post on DPF. Not like my old V10. I'm reading and learning as I go.
Old Oct 9, 2018 | 01:08 PM
Deuce40s's Avatar
Deuce40s
35% was normal for mine. Occasionally it would drop to 25% but not often.
Old Oct 9, 2018 | 01:24 PM
schlepprock250's Avatar
schlepprock250
I've been doing lots of research on this. I have my dpf % screen enabled. The mileage between regens seems a little lower than most have posted but it has never failed to regen down to 0%. It will go to 100% and down to 0% every time. '14 Lariat with 85000 miles all stock.
Old Oct 12, 2018 | 10:03 PM
n_boyd's Avatar
n_boyd
Where you driving above 35mph for awhile and then stop/go? I’ve noticed with mine as long as I’m staying in the 35-45mph range it will drop to 0% but if I hit traffic for 10 minutes or so the regen stops and starts to climb again.
Old Oct 13, 2018 | 01:48 PM
ssunit1's Avatar
ssunit1
On my '15 F250 getting down to 30-35% was normal. Only once did I notice it go as low as 15% and I never saw 0%.
RX_Boost
Feb 19, 2022 04:57 PM
zekes66
Oct 25, 2017 09:57 PM
Redneckfordf2502002
Mar 7, 2012 07:15 PM
bronzeback
Electrical Systems/Wiring
Jun 4, 2006 10:45 AM
