DEF gauge not moving.
Old Oct 20, 2017 | 11:12 PM
zekes66's Avatar
zekes66
Just curious about the DEF consumption. I have @450 miles on the F250 and the DEF gauge hasnt moved at all. Is this about right? Approx how many miles are people getting on a tank of DEF?
Old Oct 20, 2017 | 11:20 PM
Robb81's Avatar
Robb81
Normal. Mine went well over 1,000 miles before it moved much at all. Just over 4000 now and it is about half on the gauge.
wb6anp's Avatar
wb6anp
yes that should be right, Def will usually last around 5k to 7k miles depending on how much you tow.
Old Oct 20, 2017 | 11:27 PM
zekes66's Avatar
zekes66
Thanks for the responses.
Old Oct 21, 2017 | 07:52 AM
shortride's Avatar
shortride
I had the same question. Evidently the system doesn't use a lot of the DEF fluid to do its job. My truck as almost 8,000 miles on it. The DEF gauge has been on the halfway mark for the past 2,000 miles and I have never added any fluid since I bought the truck.
Old Oct 21, 2017 | 08:51 AM
Shady Camper's Avatar
Shady Camper
Same here, I thought something was wrong. I'm now at 2000 miles and it moved to just under full. When I checked with my Edge CTS2, I was at 92%.
Old Oct 21, 2017 | 09:59 AM
rwtdct's Avatar
rwtdct
I have just over 10,000 miles on mine. DEF tank was full when I bought the truck, I have added 10gal. I just had my truck serviced and the dealer filled it back up, not sure how much they added, my guess under 2 1/2gals.
Does that seem like a lot?
Old Oct 21, 2017 | 10:05 AM
A&Pmech's Avatar
A&Pmech
I used half a tank in 5000 miles. I don't tow a lot though.
Old Oct 21, 2017 | 11:14 AM
screwy's Avatar
screwy
I'm just over 10k and have added about 7 1/2 gallons, just under full now. As others have mentioned, DEF usage depends on how you're using the truck. Frequent or heavy towing will use it faster than unloaded.
Old Oct 21, 2017 | 04:46 PM
Toledo's Avatar
Toledo
i have 16k miles on mine and have only filled it up once.. i have close to 1/4 tank left.. its gonna last a while
Old Oct 22, 2017 | 08:47 AM
rwtdct's Avatar
rwtdct
Wholly Toledo...........Do you do any towing?
Old Oct 22, 2017 | 09:27 AM
HouseMouse's Avatar
HouseMouse
Same here. Truck looks great at the Grocery Store although.
Old Oct 22, 2017 | 09:50 AM
Kevin611's Avatar
Kevin611
I will say if you tow lot like I do it goes fast! Im just over 10k and have had to fill it twice my self and it had full tank when I brought it. But I say 5k of my miles is towing my 16K 5wheel.
Old Oct 22, 2017 | 10:17 AM
Toledo's Avatar
Toledo
not much just every once in a while
Old Oct 23, 2017 | 11:39 PM
Longball123's Avatar
Longball123
I have 7100 miles and just filled it for the second time! Can’t wait to delete this pig!
