2013 F-350 Lariat dually 6.7 PSD 120,000 miles.
No A/C when stopped. Works fine while driving. Engine temps creep up when stopped. Engine fan not operating. Coolant and all fluid levels OK.
P0692 code set.
I can't find anything definitive online. To me it seems to be a mechanical viscous clutch fan failure. But these new trucks have so many electronics, I want to see if there is a relay or some other fault it could be before just replacing it.
Anyone ever had this code?
Anyone ever replaced the clutch fan?
It seems most of the fan issues I'm finding are of it sticking on. Mine isn't working at all.
Replaced the fan clutch. All is well now. The thought is that the wiring in the fan clutch was broke which would cause the high-voltage code (P0692).
Not sure, but it's fixed now.
