P0528 Question!
Old Apr 24, 2015 | 04:22 PM
jayc3169's Avatar
jayc3169
P0528 Question!
I've been having this code, which I get means the fan clutch is bad. Problem is, my fan clutch comes on as commanded, even when operating normally. I've tested the fan operation with my Autoenginuity and it operates perfectly but the code remains even after its cleared. Should I still replace the clutch?
Old Apr 24, 2015 | 05:18 PM
silverbullet6oh's Avatar
silverbullet6oh
Not saying this is it, just things I have heard of is, 1. Wire chaffing, check the wiring, 2. Replacing the clutch may be needed.
Old Apr 24, 2015 | 07:22 PM
cheezit's Avatar
cheezit
Iirc there was a reflash to correct some of the random p0528 codes.
Never worked, always wound up replacing them.
Old Apr 24, 2015 | 10:09 PM
craftsmangary's Avatar
craftsmangary
Every P0528 code I have seen took a new clutch to repair it.
Old Apr 25, 2015 | 12:51 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
My P0528 code never did set the light on the dash, it was always a soft or pending code found by my SGII. It was the wiring that was doing it. That was 3 years ago.
Sawbones25
6.7L Power Stroke Diesel
Oct 15, 2018 11:25 AM
abrarham
Mar 2, 2013 07:10 PM
96_F250_Deezal
Jan 19, 2013 10:13 AM
jim6liter
Jan 4, 2007 07:30 PM
KennethKvittum
Feb 24, 2004 07:22 PM
