96 powerstroke 7.3 220,000 miles. has a bully dog programmer hooked up,not through the obd port its hard wired under hood next to the fan motor.a/c inlet shroud. water was in fuel,i dropped the tank and thoroughly cleaned it. disconnected fuel lines and from lack of compressor i gravity drained the fuel lines.had to replace injector harness on passenger side rear harness, (my truck was vandolized and disrespected)it had been cut. i replaced the cam position sensor today, no change. please help
